I'm having problems with getting an oil cooler that is useable, the problems I'm having are the threads are either stripped, or it leaks from somewhere else, but, my question is, if I blank the hose holes up on the engine temporarily, until I get a useable cooler, will that cause a problem with oil circulation?
GPZ750R1 Oil Cooler
GPZ750R1 Oil Cooler
What we got here, is failure to comunicate.
snotie1965
Thanks for the replies.
I was onl;y going to block it off temporarily, so I could getting it running properly while sorting the cooler.
I'm not sure about the GPZ1100 cooler, I've already had the frame powder coated, so I don't want to have to fit any new brackets, and it has different fittings to the 750, but it is an option, thanks.
oil cooler
A mate of mine has one I'll pm you his number!
Users browsing this forum: skinnyZED and 51 guests
