Alternator
stempy
Alternator
#1 PostAuthor: stempy » Sat Jan 25, 2014 7:21 pm
What is the best alternator to fit to a Z1000 ?
Z900/Z1000
Or later type Z1000J
PUM 451
#2 PostAuthor: chrisNI » Sat Jan 25, 2014 8:07 pm
They're not all interchangeable. Which Z1000 is it?
KeithZ1R
#3 PostAuthor: KeithZ1R » Sat Jan 25, 2014 8:08 pm
got a couple of electrex units on mine seem to work well enough if you can't source a second hand one
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#4 PostAuthor: chrisu » Sat Jan 25, 2014 11:13 pm
I've got a few spares...
stempy
#5 PostAuthor: stempy » Sun Jan 26, 2014 9:00 am
I had to change the engine in my Harris last year and the engine that came out was a Z1000 A1 but with an Z1000j alternator cover fitted with the later rotor and stator
The engine I replaced that one with is a standard Z1000A1 with the original alternator
The only reason I am thinking of changing back to the Z1000J type is that the Harris fairing has been cut out to take the Z1000J type
Just need to find a rotor for a J :roll:
PUM 451
Re: .
#6 PostAuthor: zed1015 » Sun Jan 26, 2014 9:57 am
stempy wrote:I had to change the engine in my Harris last year and the engine that came out was a Z1000 A1 but with an Z1000j alternator cover fitted with the later rotor and stator
The 'J' rotor won't fit the A1 crank.
That first engine must have had a MK2 crank fitted as that has the same larger taper the same as the 'J' etc.
garyd
#7 PostAuthor: garyd » Sun Jan 26, 2014 10:38 am
Crikey...you must know too much. Does your head resemble a TeFal man?
#8 PostAuthor: Pigford » Sun Jan 26, 2014 10:40 am
garyd wrote:That first engine must have had a MK2 crank fitted as that has the same larger taper the same as the 'J' etc.
.he knows enuff - and in person is happy to explain it ALL :lol:
#9 PostAuthor: chrisNI » Sun Jan 26, 2014 12:22 pm
And if it had a Mk 2 crank it will have had Mk2 camshaft sprockets as well which is handy to know if you're swapping stuff about. An A2 also has a bigger taper than an A1 but I think it has the same camshaft sprockets as the A1. :roll:
stempy
#10 PostAuthor: stempy » Sun Jan 26, 2014 2:34 pm
Thanks for the replies I will stick with what I have got sounds a lot easier :D
PUM 451
Users browsing this forum: skinnyZED and 55 guests
