Tap sizes
Tap sizes
Hi again,
I'm going to buy a tap and dye set so that I can clean all the threads on the engine and frame on my Z1 after it's been cleaned and painted.
Can anyone help with a suggestion on the range of sizes I may need?
Many thanks
Paul Mc
Many thanks
Paul Mc
Paul, there are many threads they are mostly the usual 6M, 8M and 10M.
There are a few rare ones that have a fine pitch,.
the rare ones are..
Top shock absorber mounts on frame.. 10 or 12mm x 1.25 pitch.
Pillion peg mounts 12 mm x 1.25 pithch
Front hub disk mount 8mm x 1mm pitch.
Centre stand ... 14 mm same [as spark plugs].
Ps. just noticed Z1bman's 10 x 1mm .. I agree but can't remember where?
the rare ones are..
Beware the cheap'n'nasty sets - the taps tend to be very brittle and snapping one is a right PITA - DAMHIKIJKOK.
Avoid carbide and go for HSS.
I'd buy individual taps or single thread size sets.
You can get decent and low priced taps from China on EBay but it's a buying a pig in a poke. If you do this, make sure each purchase is below £15 - then you don't get hit by import duty and VAT.
On the other hand, I have a Draper set that I've had for years and it's not too bad but, like all sets, most of the taps and dies have never been used.
malmojoe
I bought some taps and dyes from china and I threw them in the bin, same with some stud extractors - in fact most things from china should have stayed in the ground and saved the worlds natural and energy resources 'cause the go straight back in the landfill.
Here a page that might be useful regarding bolts. These are Japanese bikes so are most likely to be JIS threads aren't they? I know the cross head screws are for JIS screwdrivers, not PH or posi. JIS Japanese Industrial Standard) is the same as metric pitch up to about 10mm then is like fine thread.
http://www.boltdepot.com/fastener-information/measuring/metric-thread-pitch.aspx
removed info about part numbers whioch was only relevant to triples.
malmojoe wrote:most things from china should have stayed in the ground and saved the worlds natural and energy resources 'cause the go straight back in the landfill.
Oh I don't know... Chop Suey is rather good and I'm partial to a pancake roll
But I do agree that the quality of Chinese stuff can be variable;a bit like Japanese stuff from the late sixties and early seventies
However I've not been that unlucky and 95+% has been fine... and I'm pretty sure that a huge proportion of the 'British' or 'American' stuff is also made in China so all you're doing when buying direct is cutting out the middle man.
Paul after much looking about and reading about it all i bought this set from of all places screwfix.
Its HSS and comes in a metal box.
Seems very good so far and covers the sizes i needed for what you are doing.
http://www.screwfix.com/p/hss-steel-tap ... 1pc/12834#
- harrythemagnum
zorded wrote:Paul after much looking about and reading about it all i bought this set from of all places screwfix.
That looks like a bloody good deal!!!
Jimmock.
I hate people I don't like !
- mick znone
[quote="malmojoe"]I bought some taps and dyes from china and I threw them in the bin, same with some stud extractors - in fact most things from china should have stayed in the ground and saved the worlds natural and energy resources 'cause the go straight back in the landfill.
brilliant, totally agree with mal, i call them virtual products, they look like the real thing but are made of cheese, the world is full of this tat, from house hold stuff to garage to work, blumin everywhere.
Nice one Al.
I have a cheap and nasty set... but so for has done the job....but realise I need a 'proper set'.
Tap sizes
I got so pissed off with my sooper dooper so called Blue Point vernier calipers which the snap on man sold me at an extortionate cost I decided to do a bit of research for decent tackle, you know Mitutoyo and such, I found a company on eBay called RDG in Myhthomroyd near Halifax, drove over and picked up 2 gorgeous Moore and Wright sets for a wee bit more that the Chinese bluepoint item. A proper engineers supply shop, really honest and helpful and best of all though I've no room for one, Myford dealers. Just for single taps not buying a full set, do get a decent thread gauge, this is what you need no point buying a full set, Presto HSS is a good make as is Dormer. Jes
You get what you pay for, supposedly I checked the new analogue and digital calipers against my old Mitutoyo micrometer neither were far out at all.
More Smiles Per Mile
Users browsing this forum: Bing [Bot] and 197 guests
