GPZ Unitrak 1100
RALPHARAMA
GPZ Unitrak 1100
#1 PostAuthor: RALPHARAMA » Sat Feb 08, 2014 4:36 pm
I'm looking for a set of good bushes that go inside the needle rollers on the swinging spindle of my '83 GPZ1100A1 uni
They look like this when they're fucked :evil:
From memory I think the ID is 15mm OD is 25 and length 37 . I'd spin some up on the lathe but they're hardened and ground :(
Ralph Ferrand
pluto
#2 PostAuthor: pluto » Sun Feb 09, 2014 7:01 pm
Mine were similarly shot, tried every where no longer available from Kawasaki, got them made in stainless steel and bought needle rollers from simplybearings.co.uk with genuine seals (still available) works a treat. The dimensions are on the cmnsl website
Dave
jonhunt
#3 PostAuthor: jonhunt » Sun Feb 09, 2014 7:52 pm
if these are what the bearing runs on they need to have a hardened surface I doubt stainless will last that long. HRC 58-64
www.ntn.co.jp/english/products/pdf/need ... pdf‎
pluto
#4 PostAuthor: pluto » Sun Feb 09, 2014 7:56 pm
Depends on how much lube and how few miles you do!
jonhunt
#5 PostAuthor: jonhunt » Mon Feb 10, 2014 9:14 am
You need lube but it won't help with the load. Yep if you dont ride it it will never break :lol:
RALPHARAMA
#6 PostAuthor: RALPHARAMA » Mon Feb 10, 2014 9:50 am
I can easily spin some up in stainless, but as Jon rightly points out, they need to be hardened.
Ralph Ferrand
pluto
#7 PostAuthor: pluto » Mon Feb 10, 2014 3:53 pm
My reasoning is I will be lucky to do 1000 miles on it each year, if it wears out in that time I sort out another one. It's got a bolt running through it so I can't believe it will snap so the only issue is reduced lifespan. Seeing as Kawasaki probably had to over engineer them incase of neglect (which they all were - so finding a good second hand one is unlikely) a reduced spec item that keeps the bike on the road has to be a sensible option - doesn't it? Or am I risking a catastrophic suspension failure?
Either way, if you find a way of making some hardened steel items perhaps you could make me some too - I would need both smaller diameter spacers, the big one is in good shape.
Good luck
Dave :D
tlc
#8 PostAuthor: tlc » Mon Feb 10, 2014 5:30 pm
Fork rechrome specialists will be able to sort them surely?
RALPHARAMA
#9 PostAuthor: RALPHARAMA » Mon Feb 10, 2014 6:01 pm
Luckily I have managed to source one from Cradley and one is OK so I'm sorted for the time being :)
Ralph Ferrand
jonhunt
#10 PostAuthor: jonhunt » Mon Feb 10, 2014 7:39 pm
by the way the technical term for f&*ked is false brunelling caused by small movements back & forth that removes the lube & wears the surface. Just being a smart arse
RALPHARAMA
#11 PostAuthor: RALPHARAMA » Thu Feb 13, 2014 1:43 pm
jonhunt wrote:by the way the technical term for f&*ked is false brunelling caused by small movements back & forth that removes the lube & wears the surface. Just being a smart arse
I know and understand the cause and result of this phenomena, though I didn't know the technical term to which you refer, but can assure you that all engineers, regardless of professional speciality, will be fully conversant with the term 'fucked'. I therefore would humbly suggest that when conveying the overall condition of a part, my use of the vernacular, is probably better use of the language, particularly as the Z1OC is unlikely to have a second member with any knowledge or understanding of the term 'false brunelling', whereas I bet close to 100% know what I mean when I say 'it's fucked' :lol:
Yeah - I speak smart arse too :lol:
Ralph Ferrand
Taffus
#12 PostAuthor: Taffus » Thu Feb 13, 2014 1:55 pm
Yep f*cked works as does googling the term to find the correct spelling :wink:
False_brinelling
RALPHARAMA
#13 PostAuthor: RALPHARAMA » Thu Feb 13, 2014 4:43 pm
That makes sense - it may derive from the dents made by the Brinell hardness testing method?
Ralph Ferrand
jonhunt
#14 PostAuthor: jonhunt » Thu Feb 13, 2014 7:58 pm
Finger trouble :D
bigrocketrider
#15 PostAuthor: bigrocketrider » Sun Feb 16, 2014 9:41 am
http://www.ebay.co.uk/itm/Kawasaki-ZX11 ... 3a892b738e
There you go VDUK. Its in the states but if you need it..............
