They look like this when they're fucked
From memory I think the ID is 15mm OD is 25 and length 37 . I'd spin some up on the lathe but they're hardened and ground
jonhunt wrote:by the way the technical term for f&*ked is false brunelling caused by small movements back & forth that removes the lube & wears the surface. Just being a smart arse
