cyl sizes
baz
cyl sizes
#1 PostAuthor: baz » Mon Feb 24, 2014 5:52 pm
hi all, can any body tell me the external dia of 900 and 1000 cyl liners please........thanks
Garn 1
#2 PostAuthor: Garn 1 » Mon Feb 24, 2014 11:47 pm
Baz, sorry for the delay, this must have slipped past.
Here is half the answer
900 bore ~ 66mm, liner ext diameter ~ 75mm
1000 bore ~ 70 mm , liner ext diameter ~ [not sure] estimate 79-80mm.
Someone will have a 1000 liner around!
baz
#3 PostAuthor: baz » Tue Feb 25, 2014 2:07 pm
cheers for that pal.............your a top man
Z1parR
#4 PostAuthor: Z1parR » Tue Feb 25, 2014 8:41 pm
1015cc liner external diameter is 75.5mm , seems it's only the holes that are bigger :wink:
0172 . Geoff Parr
#5 PostAuthor: zed1015 » Wed Feb 26, 2014 3:01 pm
Kick start equipped engines.
903cc cylinder liner OD = 74mm
1015cc cylinder liner OD = 76mm
baz
#6 PostAuthor: baz » Wed Feb 26, 2014 4:16 pm
zed1015 wrote:Kick start equipped engines.
thanks for that pal :)
Garn 1
#7 PostAuthor: Garn 1 » Thu Feb 27, 2014 12:35 am
Bad info is a lot worse than no info.
Went and rechecked my 903 liners, Zed1015 is correct, it is 74mm not 75mm.
Sorry about that! I need glasses.
Users browsing this forum: No registered users and 143 guests
