Z1R Rear Axle Nut
Fred the Zed
Z1R Rear Axle Nut
#1 PostAuthor: Fred the Zed » Mon Mar 10, 2014 8:35 pm
I'm looking to replace the rear axle nut on my Z1R with a Nylock nut. Does anyone know what thread these nuts are? (& where to get one from?)
Fred
Paid Up Member
garyd
#2 PostAuthor: garyd » Mon Mar 10, 2014 10:41 pm
Is That legal?
Not certain but I thought it needs a mechanical securing device for the MOT.
i.e. the 'R' clip.
#3 PostAuthor: zed1015 » Tue Mar 11, 2014 12:14 am
garyd wrote:Is That legal?
i.e. the 'R' clip.
'R' pin/Split pin not needed if using locking nut.
Virtually no modern machine uses R or split pins now as most use lock nuts.
Fred the Zed
#4 PostAuthor: Fred the Zed » Tue Mar 11, 2014 6:12 am
Its a case of necessity being the mother of invention. With the Dresda arm fitted, the standard axle isn't quite long enough for the R-clip arrangement but a locking nut would fit.
I'm presuming that this is either standard 'fix' when fitting a Dresda Arm or they were supplied with a different axle? Another alternative would be to have a new axle made, but that might be an expensive alternative.
Fred
Paid Up Member
#5 PostAuthor: z1bman » Tue Mar 11, 2014 9:48 am
the thread size is 18mm but not sure of the pitch?
Big Fluff
#6 PostAuthor: Big Fluff » Tue Mar 11, 2014 4:21 pm
M18 x 2.0
Fred the Zed
#7 PostAuthor: Fred the Zed » Tue Mar 11, 2014 4:31 pm
Spectacular work! Cheers guys
Fred
Paid Up Member
Fred the Zed
#8 PostAuthor: Fred the Zed » Tue Mar 11, 2014 4:45 pm
Hmmmm.... any ideas where I might get one from. A t'internet search only reveals M18x2.5 or M18x1.5 available....
Fred
Paid Up Member
Big Fluff
#9 PostAuthor: Big Fluff » Tue Mar 11, 2014 6:21 pm
Well when I say 2.0 pitch, that's what Kawasaki used for the rear spindle on a Z1000J.
I've just found a listing that says it's 1.5mm pitch for the Z1R etc. so I may be incorrect.
Have you not got any vernier calipers?
Fred the Zed
#10 PostAuthor: Fred the Zed » Tue Mar 11, 2014 7:42 pm
Big Fluff wrote:Well when I say 2.0 pitch, that's what Kawasaki used for the rear spindle on a Z1000J.
Err, I have....Am I right in thinking that you need to measure 10mm and count the number of thread peaks to find the pitch? (ie 10 peaks = 1.0mm pitch, 5 peaks=2.0mm pitch, 6.6 peaks =1.5mm pitch)
Fred
Paid Up Member
#11 PostAuthor: Ginger Bear » Tue Mar 11, 2014 8:31 pm
Spot on there Fred.... Not sure about the 6.6 though. :??
I'd bet on it being a 1.5mm pitch as opposed to the 2.5
Have a look at this lot..........
http://www.ebay.co.uk/sch/i.html?_odkw= ... t&_sacat=0
# 104
#12 PostAuthor: z1bman » Tue Mar 11, 2014 8:34 pm
z1000j & z1000D / z1r all use the same nut part no 42045018
Big Fluff
#13 PostAuthor: Big Fluff » Wed Mar 12, 2014 8:45 am
z1bman wrote:z1000j & z1000D / z1r all use the same nut part no 42045018
including the big triple H2 750 too.
jimmock
#14 PostAuthor: jimmock » Wed Mar 12, 2014 9:23 pm
I personally think it will be "fine" instead of normal standard pitch.
Standard bolt of 18mm has a pitch of 2.5mm.
Most items that can shake or vibrate loose are fine threaded.
Jimmock. :wnkr
I hate people I don't like !
Fred the Zed
#15 PostAuthor: Fred the Zed » Thu Mar 13, 2014 6:15 am
Cheers fellas
Fred
Paid Up Member
Users browsing this forum: No registered users and 134 guests
