Z1R Rear Axle Nut
- Fred the Zed
Z1R Rear Axle Nut
I'm looking to replace the rear axle nut on my Z1R with a Nylock nut. Does anyone know what thread these nuts are? (& where to get one from?)
Fred
Fred
Paid Up Member
- Fred the Zed
Its a case of necessity being the mother of invention. With the Dresda arm fitted, the standard axle isn't quite long enough for the R-clip arrangement but a locking nut would fit.
I'm presuming that this is either standard 'fix' when fitting a Dresda Arm or they were supplied with a different axle? Another alternative would be to have a new axle made, but that might be an expensive alternative.
Fred
Fred
Paid Up Member
- Fred the Zed
- Fred the Zed
Well when I say 2.0 pitch, that's what Kawasaki used for the rear spindle on a Z1000J.
I've just found a listing that says it's 1.5mm pitch for the Z1R etc. so I may be incorrect.
Have you not got any vernier calipers?
- Fred the Zed
Big Fluff wrote:Well when I say 2.0 pitch, that's what Kawasaki used for the rear spindle on a Z1000J.
Err, I have....Am I right in thinking that you need to measure 10mm and count the number of thread peaks to find the pitch? (ie 10 peaks = 1.0mm pitch, 5 peaks=2.0mm pitch, 6.6 peaks =1.5mm pitch)
Fred
Paid Up Member
Spot on there Fred.... Not sure about the 6.6 though.
I'd bet on it being a 1.5mm pitch as opposed to the 2.5
Have a look at this lot..........
http://www.ebay.co.uk/sch/i.html?_odkw= ... t&_sacat=0
- Fred the Zed
