2 wire lucas rear light
Redbeard
#1 PostAuthor: Redbeard » Sun Mar 16, 2014 9:26 pm
The lucas style rear light I have only has 2 wires standard, neither are earth and it won't work. Should it get an earth when mounted to the bike? The 2 wires I have from the loom are tail and brake and light a test light. Diagram says I should have the black/yellow earth wire but it isn't there as the light was fitted when I got it. Any ideas? Bulb/fuses are A1.
#2 PostAuthor: zed1015 » Sun Mar 16, 2014 9:29 pm
Body should be earthed so run an earth wire to one of the mounting bolts/nuts to get a good connection.
#3 PostAuthor: z1bman » Sun Mar 16, 2014 9:33 pm
just earth a piece of wire from the negative on the battery to the body of the lamp
Redbeard
#4 PostAuthor: Redbeard » Sun Mar 16, 2014 9:50 pm
Will give that a go, thanks both of you :up
jimmock
#5 PostAuthor: jimmock » Sun Mar 16, 2014 10:03 pm
Solder a wire to the bulb holder.
On the other end of the wire solder on a terminal to fit on to the lamp mounting bolt.
This way everything is inside the lamp holder assembly.
Jimmock. :wnkr
I hate people I don't like !
#6 PostAuthor: z1bman » Sun Mar 16, 2014 10:16 pm
jimmock wrote:Solder a wire to the bulb holder.
bloody hell jim a serious answer ( take note garn ) :lol: :lol: :lol: :lol:
jimmock
#7 PostAuthor: jimmock » Sun Mar 16, 2014 10:20 pm
Thank you Z1Bman,
Jimmock's the name, and solutions is my game!!!
Jimmock. :wnkr
#8 PostAuthor: ADRIAN H » Mon Mar 17, 2014 8:47 pm
Thank you Z1Bman,
:clap :clap :clap :clap :clap
Redbeard
#9 PostAuthor: Redbeard » Tue Mar 18, 2014 8:15 pm
Thanks Jim, I feel honoured that it was my question you chose to answer seriously. :lol:
jimmock
#10 PostAuthor: jimmock » Wed Mar 19, 2014 11:52 pm
Redbeard wrote:Thanks Jim, I feel honoured that it was my question you chose to answer seriously. :lol:
Yes Redbeard, after giving it great consideration I did indeed choose your question to be the ONE I answered sensibly.
Well done Redbeard!!! :party
Jimmock. :wnkr
Redbeard
#11 PostAuthor: Redbeard » Thu Mar 20, 2014 7:11 am
on a serious note I will give your suggestion a whirl this weekend mate, cheers.
Users browsing this forum: r3sc, wilsonsjw11 and 49 guests
