First Start
Mark Tiller
#31 PostAuthor: Mark Tiller » Mon Jun 09, 2014 7:14 pm
z1bman wrote:i have seen this stuff is it any good :lol: :lol: :lol: :lol:
I have used that on a flooded Jetski, it does work
07962421462
KeithZ1R
#32 PostAuthor: KeithZ1R » Mon Jun 09, 2014 7:46 pm
PAULJAC47 wrote:
PAULJAC47 wrote:Wayne if you are sure its a fuel problem, just to confirm,get a syringe a drop a little fuel(Dont overfill else you will fuel lock) into each plug hole,if she fires you know its a fuel prob,you could also try spraying a shot of brake cleaner into the air intake to see if she fires..
Like i already suggested lads!!!!
Just a thought Wayne,have you set the slides about 1mm from the bottom in all 4 cases? are you giving her full choke with the throttle fully closed? hence max vacumn? choke lifting all four plungers? pilots set one and a quarter turns out from bottom?
:oops: sorry Paul missed it
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Wayne1960
#33 PostAuthor: Wayne1960 » Mon Jun 09, 2014 9:20 pm
Ok thanks for all your valid advise. Obviously I can't do everything at once but was worried about compression so did a very quick in calculated check by putting my finger over each plug hole. Verdict was good really strong on 1,2 & 3 but felt a little weaker on 4 but it was pushing and sucking my finger so could equally be ok.
Checked filter on petrol tap and it also looked ok.
Drained the carb bowl that keeps overflowing so need to deal with that but I must admit there wasn't a lot that came out but the bowl must have filled up for it to overflow.
All pilots set at one and a quarter turns out so all good there. Not sure about sliders and 1mm!
Could floats be upside down????? Need to check the one I have the bowl off.
Thanks again for sticking with this.
Bike now finished what a joy!
#34 PostAuthor: z1bman » Mon Jun 09, 2014 9:26 pm
it is unlikely the floats are upside down but its worth checking as this would cut of the fuel completely
Wayne1960
#35 PostAuthor: Wayne1960 » Mon Jun 09, 2014 9:32 pm
180 degrees out? Can it be? How can I ensure it's not?
#36 PostAuthor: z1bman » Mon Jun 09, 2014 9:37 pm
if it was 180% out it would pop & bang when turning it over. apart from doing a proper compression test the only way of checking is to take the cam cover of & set the crank at TDC on no 1&4 cylinders
Wayne1960
#37 PostAuthor: Wayne1960 » Mon Jun 09, 2014 9:37 pm
Just checked and the float appears to be the right way up with the cut out uppermost.
So to stop petrol leaking through the overflow I adjust the tab so the float sits higher?
Compo1955
#38 PostAuthor: Compo1955 » Mon Jun 09, 2014 9:40 pm
Lower. But all floats should be about the same height
If it ain`t broke.....don`t fix it
C90
W650
ZRX1200R
Z1A
Wayne1960
#39 PostAuthor: Wayne1960 » Mon Jun 09, 2014 9:50 pm
I was pretty particular when I set the cam chain up so hope all ok there.
I'll keep checking.
Haven't swapped the leads over yet. How do you know which ones to swap? 1&4 or 2&3 or both?
Compo1955
#40 PostAuthor: Compo1955 » Mon Jun 09, 2014 9:52 pm
One coil feeds 1&4,the other feeds 2&3
C90
W650
ZRX1200R
Z1A
Garn 1
#41 PostAuthor: Garn 1 » Mon Jun 09, 2014 10:00 pm
Wayne1960 wrote:180 degrees out? Can it be? How can I ensure it's not?
With regards to ignition timing, not cam timing!
Wayne, recall I said that often the two leads from the contact breaker get swapped around. They are bullet connectors and can be simply changed over.... It requires lifting the tank and swapping the green connector to the coil with the white to the other coil. You would have seen spark at the plugs but it would be at the wrong stroke. (Note~ Could have colour coding incorrect).
Another problem maybe, you need to adjust the float levels as prescribed.
Not an easy job for the learner.
#42 PostAuthor: z1bman » Mon Jun 09, 2014 10:09 pm
the black wire from the points goes to the left coil which is 1&4 the green wire goes to the right coil which is 2&3
Wayne1960
#43 PostAuthor: Wayne1960 » Mon Jun 09, 2014 10:36 pm
Ok guys. I'll check. If you recall the real problem is no petrol getting into chamber as plugs are dry.
neilbarrett
#44 PostAuthor: neilbarrett » Mon Jun 09, 2014 10:45 pm
have you given it a shot of easy start or put some petrol in the bores to see if it fires?
weaver
#45 PostAuthor: weaver » Tue Jun 10, 2014 7:04 am
neilbarrett wrote:have you given it a shot of easy start or put some petrol in the bores to see if it fires?
+1
