I have used that on a flooded Jetski, it does work
First Start
- Mark Tiller
PAULJAC47 wrote:PAULJAC47 wrote:Wayne if you are sure its a fuel problem, just to confirm,get a syringe a drop a little fuel(Dont overfill else you will fuel lock) into each plug hole,if she fires you know its a fuel prob,you could also try spraying a shot of brake cleaner into the air intake to see if she fires..
Like i already suggested lads!!!!
Just a thought Wayne,have you set the slides about 1mm from the bottom in all 4 cases? are you giving her full choke with the throttle fully closed? hence max vacumn? choke lifting all four plungers? pilots set one and a quarter turns out from bottom?
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Ok thanks for all your valid advise. Obviously I can't do everything at once but was worried about compression so did a very quick in calculated check by putting my finger over each plug hole. Verdict was good really strong on 1,2 & 3 but felt a little weaker on 4 but it was pushing and sucking my finger so could equally be ok.
Checked filter on petrol tap and it also looked ok.
Drained the carb bowl that keeps overflowing so need to deal with that but I must admit there wasn't a lot that came out but the bowl must have filled up for it to overflow.
All pilots set at one and a quarter turns out so all good there. Not sure about sliders and 1mm!
Could floats be upside down????? Need to check the one I have the bowl off.
Thanks again for sticking with this.
Bike now finished what a joy!
With regards to ignition timing, not cam timing!Wayne1960 wrote:180 degrees out? Can it be? How can I ensure it's not?
Wayne, recall I said that often the two leads from the contact breaker get swapped around. They are bullet connectors and can be simply changed over.... It requires lifting the tank and swapping the green connector to the coil with the white to the other coil. You would have seen spark at the plugs but it would be at the wrong stroke. (Note~ Could have colour coding incorrect).
Another problem maybe, you need to adjust the float levels as prescribed.
Not an easy job for the learner.
neilbarrett
- ZedHead
