Leaking from carb overflow only on number 2
Hasbeen
#1 PostAuthor: Hasbeen » Mon Jun 23, 2014 7:20 pm
Easy I thought, the bikes been stood a while, so I removed carbs, cleaned the float valve.
Put some new fuel lines and fitted in line filters and I thought that would be the end of it. Nope still leaks only a few drips a minute but it bugs me.
Ok, plan B. Ordered a carb overhaul kit and fitted the new valve and seat. Just put it back together, guess what no difference..........
Any ideas/advice appreciated, I must be missing something.
Its a 1000 a1
Nick
#2 PostAuthor: PAULJAC47 » Mon Jun 23, 2014 7:22 pm
Float not upside down by any chance? or check the little brass pipe at float bottom these sometimes split letting fuel through....PaulJ
Or hole in float!!!!
Hasbeen
#3 PostAuthor: Hasbeen » Mon Jun 23, 2014 7:24 pm
No it looks the same as the others.............
Hasbeen
#4 PostAuthor: Hasbeen » Mon Jun 23, 2014 7:26 pm
Do you mean the pipe in the bowl which attaches to the overflow?, not checked that
#5 PostAuthor: PAULJAC47 » Mon Jun 23, 2014 7:26 pm
Make a manomter to check fuel height from piece of clear tube,put float in petrol see if it leaks,ie sits lower than the others
Hasbeen
#6 PostAuthor: Hasbeen » Mon Jun 23, 2014 7:27 pm
Getting good at taking carbs off now tho!!
#7 PostAuthor: PAULJAC47 » Mon Jun 23, 2014 7:27 pm
Hasbeen wrote:Do you mean the pipe in the bowl which attaches to the overflow?, not checked that
Yes see above as well
Hasbeen
#8 PostAuthor: Hasbeen » Mon Jun 23, 2014 7:31 pm
Ok, I will take the buggers off again lol, thanks for the advice thus far. Will post what I find.
#9 PostAuthor: z1bman » Mon Jun 23, 2014 7:36 pm
make sure the float isnt touching the side of the float bowl?
baz
#10 PostAuthor: baz » Mon Jun 23, 2014 7:42 pm
stop putting them on the bike and try them on the bench !! :D
Hasbeen
#11 PostAuthor: Hasbeen » Mon Jun 23, 2014 7:57 pm
You guys are good. It seems the little brass pipe leaks, how does that happen?, I filled bowl with soapy water and blew up pie and bubbles!!
Whats the solution guys now please?
steve bowdler
#12 PostAuthor: steve bowdler » Mon Jun 23, 2014 7:57 pm
Swap float bowls to see if the fault moves :)
#13 PostAuthor: PAULJAC47 » Mon Jun 23, 2014 7:59 pm
Hasbeen wrote:You guys are good. It seems the little brass pipe leaks, how does that happen?, I filled bowl with soapy water and blew up pie and bubbles!!
New bowl or i have had success with a fine blow torch and solder you will find there is a hairline split in the pipe,Glad to help Paul J
Hasbeen
#14 PostAuthor: Hasbeen » Mon Jun 23, 2014 8:02 pm
Thanks Paul, really appreciate the help.
Nick
#15 PostAuthor: z1bman » Mon Jun 23, 2014 8:07 pm
http://www.ebay.co.uk/itm/Brass-Tubes-2 ... 53f042efb0
just twist the brass tube with some pliers & it should come out
Users browsing this forum: No registered users and 171 guests
