z1bman wrote:have you checked the slide heights?
Yes - did that yesterday.
Followed the Kawasaki Manual.
Set gap between Pulley Stopper & Cable Bracket at 1.8mm
Then set clearance at bottom of slides to 0.7mm
Is this the correct method?
Pigford wrote:Check pilot jets again - may need to return needle clip but go up 1 x size on pilots
z1bman wrote:i would try lowering the slide height to 0.6 mm & make sure you are measuring from the top of the slot in the bottom of the slide ?
