Rear wheel spacers [again]
jimmock
#16 PostAuthor: jimmock » Tue Dec 02, 2014 7:08 pm
walshyco wrote:
z1bman wrote:
jimmock wrote:Buy a lathe !!!
:lol: :lol:
The only way I could fit a lathe in would be to get rid of the bike. But thanks for the advice :wink:
Here is the solution.....
Sell the bike.
Buy a lathe.
Make the spacer.
Sell the lathe.
Buy back the bike!!!
It is fairly obvious to me.
Why can you Guyz NOT see the things I can????
Jimmock. :wnkr
I hate people I don't like !
walshyco
#17 PostAuthor: walshyco » Tue Dec 02, 2014 7:31 pm
jimmock wrote:
walshyco wrote:
:lol: :lol:
Sell the bike.
Buy a lathe.
Make the spacer.
Sell the lathe.
You Jimmock, are what is known as a visionary, you have amazing insight. I am impressed. You aren't selling a lathe are you?
jimmock
#18 PostAuthor: jimmock » Tue Dec 02, 2014 7:44 pm
walshyco wrote:
jimmock wrote:
walshyco wrote:
:lol: :lol:
Sell the bike.
Buy a lathe.
Make the spacer.
Sell the lathe.
Sorry,
Sold them BOTH about 3 weeks ago.
Jimmock. :wnkr
nicomkii
Re: Rear wheel spacers [again]
#19 PostAuthor: nicomkii » Mon Dec 10, 2018 7:28 am
I'm having similar issues with going from spoke to cast. Looking at the centre spacer ( # 42010-039 ) the space looks to be around 70mm. Hard to see with a rule and shoddy eyes, The spacer I have is 86mm. I know the main reason of the spacer is to stop the bearings being crushed so would like to mill it down as accurate as possible.
Has anyone got the correct measurement for that part ??
Nico
trikerdrew
#20 PostAuthor: trikerdrew » Mon Dec 10, 2018 12:08 pm
Worth a look on here as they do parts diagrams
https://www.cmsnl.com/kawasaki_model11368/
My other idea(amazing two ideas, I Know) measure the distance between axle plates. Measure everything you have and see what discrepancy you have.
Good luck
RGH
#21 PostAuthor: RGH » Mon Dec 10, 2018 12:36 pm
nicomkii wrote:I'm having similar issues with going from spoke to cast.
did my spoke to cast 18 months ago, the thin tin steady'er was mankeled when bearings removed from Z1000H cast, , cost me over $100 for NOS spacer, it needs too be in good nick Nic otherwize you'll never get your axle thru. (alignment)
nicomkii
#22 PostAuthor: nicomkii » Mon Dec 10, 2018 12:50 pm
You're a legend thats exactly what I need RGH. You wouldn't have measured the one on the sprocket side by any chance would have you ??
My one is still straight so should be good once I machine it down.
Nico
RGH
#23 PostAuthor: RGH » Mon Dec 10, 2018 1:25 pm
yes, do you have the part number so we dont get balls'ed up, got them all. be late tomorow nite before get back too ya.
Big Fluff
#24 PostAuthor: Big Fluff » Mon Dec 10, 2018 4:48 pm
I have a lathe and am happy to turn down to required size if you want.
I would need confirmed dims etc.
Will
#25 PostAuthor: chrisNI » Mon Dec 10, 2018 8:07 pm
This is the wheel that used to be in my A1 and all the relevant spacers in the order they fitted - axle nut could be either end probably wrong way round here but spacers are right caliper went outside last chrome spacer
nicomkii
#26 PostAuthor: nicomkii » Mon Dec 10, 2018 11:09 pm
RGH wrote:yes, do you have the part number so we dont get balls'ed up, got them all. be late tomorow nite before get back too ya.
42036-033
Thanks for the offer Will, love to come up there for a holiday sometime but I have access to a lathe down here in Aus :D :D
Chris you actually have the axle nut at the right end if the parts diagram is anything to go by. There is one sleeve in the sprocket carrier that I need measurements for re the above part number.
Nico
#27 PostAuthor: chrisNI » Tue Dec 11, 2018 10:10 am
42036-033
That’s the one pictured in the middle of the axle - goes inside the sprocket carrier but it’s 42036-024 on the parts diagram for the A1 - to the best of my knowledge the spacers on mine are the same ones that came out of the spoked wheels.
walshyco
#28 PostAuthor: walshyco » Tue Dec 11, 2018 12:37 pm
I put alloy wheels onto my A1, the only spacer that was different was the one in the picture that’s nearest the nut, it’s a bit smaller, also needed a different sprocket carrier for alloy wheels. I can’t give you the measurements at the moment I can’t get access to my bike at the moment. Sean.
#29 PostAuthor: ADRIAN H » Tue Dec 11, 2018 1:39 pm
walshyco wrote:I put alloy wheels onto my A1, the only spacer that was different was the one in the picture that’s nearest the nut, it’s a bit smaller, also needed a different sprocket carrier for alloy wheels. I can’t give you the measurements at the moment I can’t get access to my bike at the moment. Sean.
+1 the only one that is different is the sleeve / coupler - Sproket side.
RGH
#30 PostAuthor: RGH » Tue Dec 11, 2018 1:42 pm
sorry don't have that measurement for 42036-033
if your stuck, you can drop in sometime and l'll drop my wheel out so you can size up all the collars spaces, only takes a few minutes.
Users browsing this forum: No registered users and 97 guests
