Clearances
#16 PostAuthor: Pigford » Thu Dec 11, 2014 7:27 am
Richard Q wrote:
jimmock wrote:
KeithZ1R wrote:Told you :D
You did !!! :hys
Indeed he did :)
anyhoo - so No. 1, from 245 to 205 gives me an extra 0.4mm of clearance, which multiplied by 39.37 to give me thou = 15.748 thou. Less the 12 its already open, leaves 3.748 thou clearance.
Correct?
Richard
NOOOOOOOOOOOOOOOOOOO
Go METRIC - It'll save a balls-up later on :lol:
Richard Q
#17 PostAuthor: Richard Q » Thu Dec 11, 2014 9:10 am
Ok, valve clearances quoted are 2 - 4 thou, or 0.05mm to 0.1mm
I have minus 12 thou - or 0.3mm, so if I go for a 205, instead of the existing 245, I will have an extra 0.4mm, less the 0.3 open valve, which leaves 0.1mm
Correct?
I am just trying to ensure that I don't make any silly mistakes as I have never worked on an engine using shims before, especially ones in mm, or in fact microns, when specified clearances are in thousands of an inch.
Richard
1976 KZ900
KeithZ1R
#18 PostAuthor: KeithZ1R » Thu Dec 11, 2014 9:18 am
Pretty sure in the back of the Workshop manual there is a lookup chart that works it all out for yous
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
#19 PostAuthor: Pigford » Thu Dec 11, 2014 12:01 pm
Correct .................. a 245 shim is 2.45mm thick.
eg: So to increase clearance by 0.1mm - go for a 235 shim
Keefleaf
#20 PostAuthor: Keefleaf » Thu Dec 11, 2014 3:05 pm
If you get stuck P.M. Buzzard.
He's set up for all cylinder head work- lots of knowledge+machinery
' :wink:
jimmock
#21 PostAuthor: jimmock » Thu Dec 11, 2014 4:02 pm
Now this kinda thread is why I'm on here Guyz!!!
It gets me "all going" !!!!
Jimmock. :wnkr
I hate people I don't like !
Richard Q
#22 PostAuthor: Richard Q » Fri Dec 12, 2014 9:13 am
Is Jerry about at the moment?
Can seem to reach him on PM :)
1976 KZ900
#23 PostAuthor: Ginger Bear » Fri Dec 12, 2014 5:01 pm
It can sometimes take a while to get a response from Jerry...... Just be patient.
# 104
#24 PostAuthor: zed1015 » Sat Dec 13, 2014 6:02 pm
Richard Q wrote::??
Correct?
Richard
You need to go for 0.10 to 0.15mm ( 4 to 6 thou )
Kawasaki amended the clearance specs to the wider figures and only specified the imperial equivalent for the Americans who refuse to go metric and for the early 70's mechanic who didn't have a set of metric feelers coz they were only used to working on oily old brit stuff.
Also I strongly advise not to use shims as thin as 205mm for the head rebuild.
You will soon need to pull the head apart again to trim the valves as you will quickly run out of shim sizes as 200 is the thinnest.
You need to set the valve heights now so that you start with at least 2.5 mm shims which will ensure plenty of miles before major head work is needed again.
Users browsing this forum: celger7, Tinker, Ultim8pc and 50 guests
