Saxon Turbo nears completion with new pics
- RALPHARAMA
Oooh err. Me like!
Ralph Ferrand
- paul doran
Rich wrote:paul doran wrote:Big Fluff are those Mick Grant adjustible bars you have fitted
Jota bars
Correct Rich... Steve Cundalls kindly donated them
Anyway, just got back from France so will now get 'stuck in' and finish it off.
VDUK - The pipe has no baffles and is staying like that, just putting a small heatshield on it tomorrow or me leg'll look like a stick of salami
It's been a ballache but i've managed to come up with a way of mounting up to date Koito flat glass headlamps into the original bowls that sit in the fairing cutouts.... all the small jobs take bloody ages don't they ?
Also, the side stand is a modified Rickman job which has had the spring point removed and a curly foot grabber welded on, all very nice job by S+S Performance but useless for my new 'growler' exhaust. Besides, I hate the way you have to dismount the bike before you can put the side stand down.!
So i've modified a standard zed item and added an extra pivot point on the chassis stand bracket so it now works like a standard zed stand, much better me thinks.
Tomorrow I will be finishing off the headlamps & wiring. I will also be mounting the steel tank with the new larger bore taps (that include a reserve) and looking at why the rear wheel goes tight when the axle nut is nipped up.
Till then......
Till then......
Good old Rickman side stands, never dug in but putting it down whilst leaning the bike over was a knack
Look for a sidestand spring with a long straight on it as it will clear your old lug and the bolt head. Std Kawa will do I think.
You'll be having the usual "one black boot"
free langth = 115mm internally
distance from longest loop to start of spring = 42mm
As this one
http://cgi.ebay.com/ebaymotors/KAWASAKI ... dZViewItem
As this one
