Z1000 MK2 Timing data ....any one know ???
johny brando
#1 PostAuthor: johny brando » Wed Mar 04, 2015 6:30 am
Z1000 Mk 2 ignition timing data .......I can't seem to find it anywhere CAN YOU PLEASE HELP ! I know it's fully advanced at 3400 rpm thats all I can find on it.... but I'd like to know where it is in degree's when it's Retarded & what degree's BTC it is when it's fully advanced & if possibly at what rev's doe's the Advance start to cut in. I'm running it on a 900 & it runs OK but I don't know if it possibly could be doing any damage or not. All the data's readily available for a 900 but ziltch for a MK2. I'd be grateful if any one can shed some light. Cheers. [/b]
#2 PostAuthor: chrisu » Wed Mar 04, 2015 9:53 am
book says 10 degrees BTDC at 1000rpm to 40 degrees at 2350rpm
#3 PostAuthor: zed1015 » Wed Mar 04, 2015 9:56 am
Full advance is 40 degrees btdc on all the 900 and 1000's if you are going by the book on a std engine.
Once you have that set with a strobe the retarded figure is fixed by the mechanical advance and can't be altered independently without modifying the advancer.
Jay1969
#4 PostAuthor: Jay1969 » Wed Mar 04, 2015 12:16 pm
Whilst on this subject, are adjustable cam sprockets
the ultimate for accuracy when mechanically retarding
the timing, or are adjustable cam sprockets only required for high lift cams?
~Jay.
#5 PostAuthor: zed1015 » Wed Mar 04, 2015 7:46 pm
Jay1969 wrote:Whilst on this subject, are adjustable cam sprockets
~Jay.
Not sure what you mean.
Adjustable cam sprockets bear no relation to the ignition timing.
However! adjustable cam sprockets are of use even in a STD engine as manufacturing tolerances means that the cam timing is hardly ever spot on from the factory and degreeing them in can help crispen up the motor and find a little more power.
johny brando
Data-THANKS !
#6 PostAuthor: johny brando » Wed Mar 04, 2015 8:29 pm
chrisu wrote:book says 10 degrees BTDC at 1000rpm to 40 degrees at 2350rpm
Thanks alot Chris !!! thats exactly what I was after mate. It really needed some one with a preferably a factory manual to answer that one. Now I can see where the timing differs from a 900 ( i.e. 20----40 degrees BDC & from 1500--2350 rpm) as oppose to the MK2 with a wider differential of ( 10----40 degrees BTC advancing over a longer period from 1000---3400 rpm ) Cheers :wink:
johny brando
#7 PostAuthor: johny brando » Wed Mar 04, 2015 8:49 pm
zed1015 wrote:Full advance is 40 degrees btdc on all the 900 and 1000's if you are going by the book on a std engine.
Thanks for that Rob . I'm not looking to alter the A & R unit I just wanna find out the difference between em... thats why it was Data specific questions. Thanks for your input mate. Cheers Johny B
Jay1969
#8 PostAuthor: Jay1969 » Wed Mar 04, 2015 9:02 pm
~Jay.
Thanks Rob, you are simply the best :D
~Jay.
Users browsing this forum: zapo and 77 guests
