Not sure what is the best thing to do
1. Use a torque wrench on the cap bolts ( I have previously had problem with stripping the treads on a z1100 so I am very wary of using a torque wrench.
2. Use a small ratchet and thread lock to tighten the bolts.
Tightening Camshaft caps
Z1000 MK2
Z1300 DFI
Z1300 DFI
This subject comes up quite a bit, I recall one guy on this forum insisted that you should always use a torque wrench. I think the problem with these cam-cap bolts came up when there was a misprint in one of the Z1 manuals, calling for 16 ft/lbs instead of 16 in/lbs or some such numbers. Nevertheless, I agree with Zed1015, you do develop a feel with a lighter ring or tee spanner on these critical 6mm bolts.
Every now and then I run a 'fluteless' tap down the holes, just to cold form any distortion back into the correct order. This also strengthens the thread in the head.
nicomkii wrote:And when using the 10mm spanner 'choke' the spanner don't use the end for any leverage. Hold it up closer to the bolt, you'd be surprised how much difference that makes.
this good advice and the way i've always done it alongside the " if it feels tight " then " it probably is " premise they only need 1.1~1.3 kg m it aint a lot
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
Users browsing this forum: KevH and 52 guests
