GB's Modded Z900 now on a runaway budget!
#331 PostAuthor: Pigford » Fri Sep 25, 2015 8:36 am
Coming along very nicely indeed :twisted:
Hope you keep this one for a bit matey :!:
Padders
#332 PostAuthor: Padders » Fri Sep 25, 2015 8:49 am
Very very nice Steve
PUM 13
#333 PostAuthor: ZedHead » Fri Sep 25, 2015 8:56 am
Loving the zorst too ....
Have i mentioned i do Nitro :roll:
Is Vic There
#334 PostAuthor: Is Vic There » Sat Sep 26, 2015 8:55 am
That's looks good mate, I just can't get my head around the exhaust sticking up, just doesn't feel right if you know what I mean!
wilsonsjw11
#335 PostAuthor: wilsonsjw11 » Sat Sep 26, 2015 2:22 pm
Steve,
Full credit to you.
You do know how to build a special and do it properly.
Regards
Steve
#336 PostAuthor: Ginger Bear » Sun Oct 04, 2015 1:21 pm
Steve,
Your comments are much appreciated..... Thank you!
Been chipping away at a few of the smaller details;
Oil lines plumed with AN-8 'Stealth' fittings. These then required a low profile breather. :roll: Fitted with another AN-8 fitting, ready for the breather hose (which is another story in itself... more of that later).
# 104
#337 PostAuthor: Ginger Bear » Sun Oct 04, 2015 1:37 pm
Began plumbing the brakes with home made lines. :??
First off, source some old lines with stainless banjo's.
A few minutes later I've got some 'good as new' fittings. :D
Next job is to cut the new line to length. My preferred method is to wrap it with masking tape, then cut through with a Dremel. The important thing is to leave the cut as clean as possible.
I cut around 6mm of the outer sheath off.
I also opened up the nuts by 0.10mm so they'd clear the outer sheath.
Next, slide the nut over & 'open up' the stainless braid.
Slide on a new olive & give it a tap, so it fits snugly on the inner liner.
Push in the banjo & screw the whole assembly together using a little copperslip.
Job done!
# 104
PJ
#338 PostAuthor: PJ » Sun Oct 04, 2015 1:54 pm
Superb Steve
#339 PostAuthor: Ginger Bear » Sun Oct 11, 2015 7:49 pm
Brakes are now all plumbed in, as much as I'd like to bleed them, I'll wait until the wheels & mudguard come back from Hutchy, as I may need to shorten the line between the front calipers & I won't know for sure until the front muddy is fitted.
Whilst trying to jack up the front of the bike to extend the forks fully to get the brake line length correct, I had a near disaster :shock: :shock:
The height adjusters on the Micron stands, twisted with the bike almost falling of the lift......... The titanium exhaust would have been the first thing to hit the 'toaster'. :cry: :cry:
Disaster averted, I have upgraded my stands, the rear is very solid, the front is OK, but not as beefy as the rear.
Offending stands are now going begging...... First person to buy me a pint at Stafford next Saturday afternoon can have them. :beer
Looked hi & low for me Kosman clutch/sprocket outrigger. Eventually found it. I had the machined recesses polished by Mikey, then powdercoated by Nick at Griffs. Not sure if I should have had it all black, with just the Kosman polished. It'll go on as it is for now. Rebuilt it with the original (non metric) fasteners, black zinced by Mikey. Then fitted a PMC 'easy clutch' which is the same as fitted to Unitac's, making the clutch action much lighter & smoother, compared to the 'spiral' type mechanisms originally fitted.
A Hydraulic clutch ws the original plan, but there just wasn't enough meat on the outrigger to remove.
# 104
Z1parR
#340 PostAuthor: Z1parR » Sun Oct 11, 2015 7:51 pm
Bear , i'll look out for you at the beer bar :D
0172 . Geoff Parr
#341 PostAuthor: Ginger Bear » Sun Oct 11, 2015 8:10 pm
Z1parR wrote:Bear , i'll look out for you at the beer bar :D
They'll be in the van Geoff. :wink:
# 104
Is Vic There
#342 PostAuthor: Is Vic There » Mon Oct 12, 2015 6:21 am
The Micron stands are similar to the Aldi ones I have, same thing happened to me. There not man enough for a larger bike but are ok for my 250 two strokes. Bought a Harris front stand and had it shipped over with the bike, just can't suss out how it works :oops: will have another look when the bike comes back from the engineers.
tlc
#343 PostAuthor: tlc » Mon Oct 12, 2015 6:30 am
Those rear sets look familiar Steve.
Can I recommend you dismantle every last screw and bolt then refit with a touch of loctite.
#344 PostAuthor: Ginger Bear » Mon Oct 12, 2015 12:41 pm
tlc wrote:Those rear sets look familiar Steve.
So after spending a ridiculous amount of dosh on 'em the feckers are gonna fall to bits. :doh
# 104
tlc
#345 PostAuthor: tlc » Mon Oct 12, 2015 5:40 pm
The four little countersunk screws on my gear change came undone.
As did the footpeg causing an embarrassing slip into neutral.
