Z1 Seat
wheelysteve
Z1 Seat
#1 PostAuthor: wheelysteve » Fri Nov 06, 2015 7:26 pm
I know that there is a difference between seat cover design on 73-75 Z1's and Z900/Z1000's, but are the seat bases and foam the same?
If there are differences, can a Z900/1000 seat be modded to fit a Z1?
Cheers Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
mick znone
#2 PostAuthor: mick znone » Fri Nov 06, 2015 9:21 pm
the early z1 seats had black foam showing through the holes under the seat.
000zeds
#3 PostAuthor: 000zeds » Sat Nov 07, 2015 7:43 am
They can be modded :!:
Main difference is the seat catch / lock
Zeds-R-Us
wheelysteve
#4 PostAuthor: wheelysteve » Sat Nov 07, 2015 3:33 pm
So the seat base holes and hinge positions are identical?
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
#5 PostAuthor: ADRIAN H » Sat Nov 07, 2015 4:49 pm
Seat bases are very similar. The hinge position is identical.
However the mounting bolt fixing nuts for the seat catch / hoop are in different position. But is relatively easy to add new mounting nuts in correct place.
