Z1000 cams into CSR 1000
Hi guys, If I fitted Z thou cams into my CSR 1000 would I get a good power increase ? I'm only going by what I read that the CSR cams are "softer" What model thou would I use ? J model, MK2, A1 ??? thanks to all replies $tevie
stephen g mackay
The cam spec is the same on ALL kickstart 900/1000 motors within factory tolerances so any would do if they do offer a power increase but obviously cams from the later model MK2 etc will have less wear.
For a real increase though GPZ1100 Unitrack cams are the ones to fit and even though the Geep has under bucket shims it's cam profile isn't really wild enough to warrant them and will happily run over bucket shims with no problem.
Thanks for that info. I'll be looking out for some UT cams. Cheers $tevie
stephen g mackay
