Oil cooler hoses
scott
Junior Section leader
Oil cooler hoses
#1 PostAuthor: scott » Thu Nov 19, 2015 1:40 pm
I have a quote from Earls to provide two hoses for my oil cooler that I'm fitting. They want £104 for each hose, total of £208 for the two.....not cheap. They are to be 1 meter long approx and to have AN10,90 degree, black fittings. It will also need the AN10 to 1/4 NPT adaptor for the crankcase connection. The hoses must be black nylon and all fittings must be black. Anyone know where I can get these hoses made a bit cheaper?
KWACKERZ1
#2 PostAuthor: KWACKERZ1 » Thu Nov 19, 2015 1:42 pm
try your local hydraulic hose supplier, they will be a lot cheaper
scott
#3 PostAuthor: scott » Thu Nov 19, 2015 1:56 pm
Thanks Phil.....maybe i'll try Pirtek
RALPHARAMA
#4 PostAuthor: RALPHARAMA » Thu Nov 19, 2015 2:29 pm
The Ginga Bear put me onto these guys -
http://stores.ebay.co.uk/Torques-U-K?_trksid=p2047675.l2563
Cost me around £80 for the cooler pipes for my Unitrak - black anodised fittings and black nylon covered tube, exactly the same as Earles!
Ralph Ferrand
#5 PostAuthor: zed1015 » Thu Nov 19, 2015 3:18 pm
+1 for Torques.
Been using their stuff for years now .
Quality on par with earls/goodridge but much cheaper.
scott
#6 PostAuthor: scott » Thu Nov 19, 2015 3:24 pm
Thanks for the heads up guys, I'll give them a try.
Pirtek get their gear from Earls, so there would be a mark up on that.
z2.john
#7 PostAuthor: z2.john » Thu Nov 19, 2015 3:32 pm
Scott,
Pop over to Hypohose in Farlington.
scott
#8 PostAuthor: scott » Thu Nov 19, 2015 3:36 pm
Thanks John, I'll try them as well.
#9 PostAuthor: Ginger Bear » Thu Nov 19, 2015 3:42 pm
Scott, As has already been said...... Get your hoses & fittings from Alex at Torques. You won't regret it!
# 104
scott
#10 PostAuthor: scott » Thu Nov 19, 2015 4:27 pm
Oh yes, that's what I'm looking for....they look nice and....black
jimmock
#11 PostAuthor: jimmock » Thu Nov 19, 2015 4:37 pm
Now they hoses do look good.
Jimmock. :wnkr
I hate people I don't like !
Robw
#12 PostAuthor: Robw » Thu Nov 19, 2015 5:30 pm
I like that APE cover with the AN adapter, which bike is it for as I fancy one for my J.
Rob
#13 PostAuthor: Ginger Bear » Thu Nov 19, 2015 7:09 pm
Rob,
Bottom end is Z900, as you can see APE breather with (I think 1/4 NPT) - AN-8 adaptor, from......... Alex at Torques. :D
# 104
Robw
#14 PostAuthor: Robw » Thu Nov 19, 2015 8:06 pm
Cheers, doesn't look like I can get a cover for a z1000r, so I will have to modify one I already have.
Rob
#15 PostAuthor: Ginger Bear » Tue Nov 24, 2015 6:28 pm
This might be useful.....
https://youtu.be/ZAnAlLp7HMk
# 104
