Mini Lathe should do it. When you say Z is it the same for the Z1rzed1015 wrote:You can make your own out of M5 brass grub screws or threaded bar and some micro pcb drill bits.
IIRC 0.6mm is the size for the Z but you could make several sets of different sizes to fine tune to your particular set up.
Trickiest bit is not breaking the drills.
http://www.gwr-fasteners.co.uk/m5-slott ... 1740-p.asp
phil1r wrote:Mini Lathe should do it. When you say Z is it the same for the Z1rzed1015 wrote:You can make your own out of M5 brass grub screws or threaded bar and some micro pcb drill bits.
Pigford wrote:Yes, #0.6mm is apparently correct, but I think thought that was for VM33 smoothies?
I have a set of 4 x #0.6mm air jets if someone needs some
