Mirrors
Wayne1960
Mirrors
#1 PostAuthor: Wayne1960 » Sun Sep 18, 2016 8:15 pm
Is there a way of telling if I have original mirrors and can you stil get originals?
Bike now finished what a joy!
#2 PostAuthor: z1bman » Sun Sep 18, 2016 8:52 pm
originals still available at cradley but £52 each
tlc
#3 PostAuthor: tlc » Mon Sep 19, 2016 6:15 am
Pattern mirrors blur after 30mph.
Genuine ones do it after 60.
Chrisu bought some pattern ones and put in some anti vibration material which improved them considerably.
#4 PostAuthor: Garry.L » Mon Sep 19, 2016 7:24 am
As above. If you can see anything behind you much past 20mph there's a chance they're genuine.
I used some silicon behind the glass on an old pattern set and it improved them no-end.
#5 PostAuthor: chrisu » Mon Sep 19, 2016 10:28 am
tlc wrote:Pattern mirrors blur after 30mph.
Not quitecorrect chris. I bought a set of short stem mirrors off ebay from a company called yuniparts. These had metal/rubber mountings which damped vibration. I just swapped the stems for std Z length ones.
Sadly looks like they don't do them any more. I guess you could contact them to see if they do have any.
Wayne1960
#6 PostAuthor: Wayne1960 » Mon Sep 19, 2016 2:47 pm
So I had the stems re finished but the mirror bodies look cheap or should they?
Are there no typical Kawasaki numbers or marks to look out for?
Wayne1960
#7 PostAuthor: Wayne1960 » Mon Sep 19, 2016 3:39 pm
Can you get replacement glass?
#8 PostAuthor: PAULJAC47 » Mon Sep 19, 2016 3:44 pm
If you look on ebay find some pattern type mirrors but ensure the stem goes into a threaded portion on the mirror not into a brass bush which is pressed into the cheap repro ones ,then just swap the complter mirror inserts,need a bit of fiddling but i have done this with some success and no vibes!
Kev1R
#9 PostAuthor: Kev1R » Mon Sep 19, 2016 6:19 pm
From a previous thread I believe KeithZ1r recommends these which are similar to originals and come in long stem or shorter stem (for Z1R) and apparently do not vibrate.
http://www.ebay.co.uk/itm/221245531641? ... EBIDX%3AIT
From experience I would avoid the 'Emgo' make of mirrors as they simply do not work.
Kevin
010
#10 PostAuthor: PAULJAC47 » Mon Sep 19, 2016 6:24 pm
Yep there the ones!
Wayne1960
#11 PostAuthor: Wayne1960 » Mon Sep 19, 2016 6:50 pm
ok taken the mirror body off the stem and it has the brass inserts!!!!!
so there not original right?
Wayne1960
#12 PostAuthor: Wayne1960 » Mon Sep 19, 2016 7:14 pm
stripped mirror and it says KDC 77-05-16
wheelysteve
#13 PostAuthor: wheelysteve » Mon Sep 19, 2016 7:22 pm
I've got those on long stems also. They are virtually identical to the original Kawasaki items, only difference is a slightly rougher finish on the back.
I put foam in the back of mine just to make sure and they are rock steady at any legal speed Wink
I think the right hand mirror is a new genuine Kawasaki item, the other is the Yuniworld job
_________________
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Wayne1960
#14 PostAuthor: Wayne1960 » Mon Sep 19, 2016 7:35 pm
Ah now we are talking so mine are actually genuine cheap crap! i thought so as they are all plastic.
i need to get myself the genuine article
#15 PostAuthor: chrisu » Mon Sep 19, 2016 8:22 pm
Kev1R wrote:From a previous thread I believe KeithZ1r recommends these which are similar to originals and come in long stem or shorter stem (for Z1R) and apparently do not vibrate.
Kevin
That's them. Same company
Users browsing this forum: Bing [Bot] and 59 guests
