Z650 Kickstart gear mechanism/pawl.
#1 PostAuthor: zed1015 » Fri Oct 21, 2016 12:06 pm
Z650 kickstart mechanism needed for a cunning plan.
Should be 20 tooth i believe.
Any condition just so I can see if it's gonna work or not.
#2 PostAuthor: warren3200gt » Fri Oct 21, 2016 3:45 pm
650 is 20T. Got a parts diagram and part no's list if it helps. Got 2 shafts but both in running engines so not a lot of use to you.
or alternatively
http://www.ebay.co.uk/itm/Kawasaki-Z650 ... Sw-kdX1-ed
#3 PostAuthor: zed1015 » Fri Oct 21, 2016 5:00 pm
Thanks for confirming it is 20t.
I counted them on a pic on an ebay listing.
Just need one to try now.
Not paying DK's fantasy prices though.
Probably only need the actual gear when all said and done.
#4 PostAuthor: warren3200gt » Fri Oct 21, 2016 5:21 pm
13068-035 part no for the 20t cog. Looks like the same part no for all 650's according to partzilla. But no longer available.
GPRD
#5 PostAuthor: GPRD » Fri Oct 21, 2016 7:11 pm
I should have one for an engine I'm rebuilding, what do you need?
What we got here, is failure to comunicate.
#6 PostAuthor: Ginger Bear » Fri Oct 21, 2016 7:53 pm
I can't wait to see what the 'cunning plan' is. :sou
# 104
#7 PostAuthor: zed1015 » Fri Oct 21, 2016 8:19 pm
GPRD wrote:I should have one for an engine I'm rebuilding, what do you need?
Hopefully just the gear to see if it's close.
Don't think I need the ratchet pawl half as that looks to have the same 12 teeth as the z9/1000 and should match.
#8 PostAuthor: zed1015 » Wed Oct 26, 2016 11:14 am
BUMP.
Crofty
#9 PostAuthor: Crofty » Tue Nov 01, 2016 11:55 pm
PM sent
