Misfire
mikey
Misfire
#1 PostAuthor: mikey » Mon Jan 09, 2017 7:30 pm
Not an old Z but a GPz1000rx, start it up from cold runs absolutely fine,
couple miles down the road starts to misfire badly and rev counter needle
drops and rises with the misfire ? just started doing this yesterday,
leave it to stand for an hour start it up and its fine again until a couple of
miles down the road again.
My guess is something electrical breaking down when it gets warm.
#2 PostAuthor: Pigford » Mon Jan 09, 2017 7:33 pm
Coils are prone to failing like that when hot :?:
Dunno if the clox are trying to tell you summink else :??
mikey
#3 PostAuthor: mikey » Mon Jan 09, 2017 7:39 pm
Exactly what i was thinking mark with the coils
but with the tacho needle behaving like that
makes me wonder if its the cdi unit ?
#4 PostAuthor: zed1015 » Mon Jan 09, 2017 7:49 pm
Rev counter is triggered by the coils so most likely a duff coil.
#5 PostAuthor: z1bman » Mon Jan 09, 2017 7:50 pm
has it still got the side stand switch fitted? also plug gaps are prone to corroding look up inside the cap for corrosion as the plug chamber fills up with water
mikey
#6 PostAuthor: mikey » Mon Jan 09, 2017 8:53 pm
No side stand switch ill check plug caps.
Cheers for the heads up on the coils rob.
Julian_Boolean
#7 PostAuthor: Julian_Boolean » Mon Jan 09, 2017 9:13 pm
Sounds like a coil is on the way out
sid123
#8 PostAuthor: sid123 » Tue Jan 10, 2017 8:42 pm
check connections and condition of pick up coils on end of crank
whoosh im gone
mikey
#9 PostAuthor: mikey » Thu Jan 26, 2017 8:01 pm
Sid.... you were bang on the mark
wires to the pick ups had gone brittle and hard
and when they got hot were separating.
My brothers quite clever at fixing fiddly things like that
soldered in new wire problem gone
Users browsing this forum: No registered users and 155 guests
