Z1100r my tale of woe
FOZ1A
1100
#91 PostAuthor: FOZ1A » Wed Jan 25, 2017 3:08 pm
Can i ask how much did they charge to do the crank, as i have one that needs doing.
foz
swampy
#92 PostAuthor: swampy » Wed Jan 25, 2017 3:16 pm
You sure can Robin Applebe engineering did the job.
Strip,clean,inspect,balance and weld with new big ends and mains came to £580.
FOZ1A
1100
#93 PostAuthor: FOZ1A » Wed Jan 25, 2017 3:18 pm
Foz
Julian_Boolean
#94 PostAuthor: Julian_Boolean » Wed Jan 25, 2017 4:13 pm
swampy wrote:You sure can Robin Applebe engineering did the job.
Was it a Z1100R crank or one from something else?
(I thought the 1100R had the Unitrak engine and the crank came from the factory with the centre pin welded)
swampy
#95 PostAuthor: swampy » Wed Jan 25, 2017 7:20 pm
original z1100r crank
Julian_Boolean
#96 PostAuthor: Julian_Boolean » Wed Jan 25, 2017 7:49 pm
Was the centre pin welded before it went for refurb - just wondering as I have a Unitrak crank and hope that it's welded.
swampy
#97 PostAuthor: swampy » Wed Jan 25, 2017 7:57 pm
No the pin was not welded as i recall but i could be having a senior moment there.
Basically my intructions where do the bussiness to it.
swampy
Re: Z1100r my tale of woe
#98 PostAuthor: swampy » Thu Mar 02, 2017 10:12 am
ok quick up date head has had new seats cut, vale guides installed and had ports matched/stage 1 flowed all done by Roger Upperton. new valves, springs, followers fitted along with slotted sprockets new cam shells and the cleaned up and deburred cam. head bolted on with hd studs and nuts
swampy
#99 PostAuthor: swampy » Mon Oct 23, 2017 9:44 am
Been a while since my last update but after much grief swearing and hitting the resto wall. the engine is together, the chain conversion and offset sprocket sorted. Along with much jiggery pokery to get the Kerker to clear swing arm bracing..... WELL...
IT LIVES! :hoo :hoo :hoo
#100 PostAuthor: Pigford » Mon Oct 23, 2017 12:45 pm
looks a million $$$ - which it probably is :lol:
#101 PostAuthor: Ginger Bear » Mon Oct 23, 2017 1:54 pm
Looks FAB.
Club stand hasn't seen a lot of Green recently. :wink: :wink:
# 104
swampy
#102 PostAuthor: swampy » Mon Oct 23, 2017 2:20 pm
probably cost me more than the bikes value. but its worth it to me as i wanted one since they were released. i only had to wait 30yrs.
if the club wants to use it for a display stand, no problem.
wheelysteve
#103 PostAuthor: wheelysteve » Mon Oct 23, 2017 2:27 pm
Very nice Swampy, well worth the grief !!
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
#104 PostAuthor: Pigford » Mon Oct 23, 2017 3:39 pm
swampy wrote:probably cost me more than the bikes value. but its worth it to me as i wanted one since they were released. i only had to wait 30yrs.
Tell me about it - me Harris for one :lol:
Still a great hobby (these bikes) as you can always get a bulk of the value back if needed ..... Get it on the stand lad :twisted:
SVENLEATHER
#105 PostAuthor: SVENLEATHER » Mon Oct 23, 2017 11:32 pm
BHS meeting next year then swampy? Look better at the end than this year.
