Z1100r my tale of woe
Julian_Boolean
swampy wrote:You sure can Robin Applebe engineering did the job.
Strip,clean,inspect,balance and weld with new big ends and mains came to £580.
Was it a Z1100R crank or one from something else?
(I thought the 1100R had the Unitrak engine and the crank came from the factory with the centre pin welded)
Julian_Boolean
Re: Z1100r my tale of woe
ok quick up date head has had new seats cut, vale guides installed and had ports matched/stage 1 flowed all done by Roger Upperton. new valves, springs, followers fitted along with slotted sprockets new cam shells and the cleaned up and deburred cam. head bolted on with hd studs and nuts
Been a while since my last update but after much grief swearing and hitting the resto wall. the engine is together, the chain conversion and offset sprocket sorted. Along with much jiggery pokery to get the Kerker to clear swing arm bracing..... WELL...
IT LIVES!
IT LIVES!
looks a million $$$ - which it probably is
Looks FAB.
Club stand hasn't seen a lot of Green recently.
probably cost me more than the bikes value. but its worth it to me as i wanted one since they were released. i only had to wait 30yrs.
if the club wants to use it for a display stand, no problem.
- wheelysteve
Very nice Swampy, well worth the grief !!
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
swampy wrote:probably cost me more than the bikes value. but its worth it to me as i wanted one since they were released. i only had to wait 30yrs.
Tell me about it - me Harris for one
Still a great hobby (these bikes) as you can always get a bulk of the value back if needed ..... Get it on the stand lad
- SVENLEATHER
BHS meeting next year then swampy? Look better at the end than this year.
