Z1000 master cylinder + silicon brake fluid ?
mike_p
#1 PostAuthor: mike_p » Tue Jan 17, 2017 12:25 pm
Does anyone know where I can get a stainless bolt for the side of the master cylinder on a z1000 ? Not really sure what its there for really unless its a spare port for something.
Also has anyone on here used DOT 5 Silicon brake fluid without problems ? As I'm rebuilding all the brakes and replacing all lines/seals etc I'm wondering if this is a good idea....no paint damage, doesn't absorb water etc etc
#2 PostAuthor: z1bman » Tue Jan 17, 2017 12:39 pm
if you mean this adjuster bolt ? i have not seen anyone advertising them for sail in stainless. as for using silicone b/ fluid that's all i ever use
http://z-fever.de/shop/product_info.php ... g-set.html
mike_p
#3 PostAuthor: mike_p » Tue Jan 17, 2017 5:10 pm
No it's not that one.....cheers though....I should have said it's the rear master cylinder......not the front. It's on the outside of the rear master cylinder, pretty much in the middle ?
Gus
#4 PostAuthor: Gus » Tue Jan 17, 2017 5:43 pm
do you mean item 6?
Gus
"Set the GRINDER on it"
mike_p
#5 PostAuthor: mike_p » Tue Jan 17, 2017 5:59 pm
Yeah that's the one....cheers Gus.....anyone know of a stainless version ?
mike_p
#6 PostAuthor: mike_p » Fri Jan 27, 2017 11:18 pm
Nobody know of any source for this bolt....item 6 on drawing ? If not I may just have to get one made up in stainless
#7 PostAuthor: ADRIAN H » Sat Jan 28, 2017 10:36 am
Phil Denton engineering should be able to make you one. Have bought a few stainless parts off them in the past.
Never seen one for sale. Could buy a complete rear master cylinder off ebay ?
mike_p
#8 PostAuthor: mike_p » Sat Jan 28, 2017 10:54 am
Cheers Adrian....I think getting one made is looking like the only option
DavidZ1R
#9 PostAuthor: DavidZ1R » Sat Jan 28, 2017 2:13 pm
I was told by DaveMarsden when I was refurbishing my rear master cylinder what ever I did, do not lose that nut, I would struggle to get another, could be an investment opprtunity there :D
Users browsing this forum: Google [Bot] and 69 guests
