Does anyone know where I can get a stainless bolt for the side of the master cylinder on a z1000 ? Not really sure what its there for really unless its a spare port for something.
Also has anyone on here used DOT 5 Silicon brake fluid without problems ? As I'm rebuilding all the brakes and replacing all lines/seals etc I'm wondering if this is a good idea....no paint damage, doesn't absorb water etc etc
Z1000 master cylinder + silicon brake fluid ?
if you mean this adjuster bolt ? i have not seen anyone advertising them for sail in stainless. as for using silicone b/ fluid that's all i ever use
http://z-fever.de/shop/product_info.php ... g-set.html
Phil Denton engineering should be able to make you one. Have bought a few stainless parts off them in the past.
Never seen one for sale. Could buy a complete rear master cylinder off ebay ?
Users browsing this forum: Google [Bot] and 61 guests
