ZRX Chain Adjusters?
LeeJackson
#1 PostAuthor: LeeJackson » Sun Feb 12, 2017 12:10 pm
Chaps,
I was just removing my rear wheel to fine tune the chain alignment and the axle galled up in the chain adjuster I had fitted on the chain side. The adjuster I got with the swingarm were machined parts rather than genuine. Axle is jammed solid for now, but It was always a bit tight, so I decided to fit the zephyr ones I had instead.
When I matched them up side by side I noticed that the Zephyr ones are actually two different lengths, but the home made ZRX ones I had were not.. So I am wondering if the genuine ZRX ones are two different lengths? It will obviously affect the wheel alignment. Does anyone know what lengths the ZRX ones are supposed to be?
If they are different lengths, which side does each go on?
Lee
LeeJackson
#2 PostAuthor: LeeJackson » Sun Feb 12, 2017 12:47 pm
Ok the which goes on which side was a stupid question, they can only go one way with axle coming in from the left :) So just need to know what they measure I guess.
Lee
Coose
#3 PostAuthor: Coose » Sun Feb 12, 2017 4:28 pm
Looking on CMSNL the ZRX adjusters are different part numbers, with the left-hand one being some €17 cheaper than the right-hand. That maybe indicates that the narrow one is on the left, though sadly there are no dimensions so this post probably hinders more than helps.... :wink:
LeeJackson
#4 PostAuthor: LeeJackson » Sun Feb 12, 2017 4:59 pm
haha pretty Much. Anyway all ok as I managed to ungaul with some heat and a hammer.. :) just before going to the pub full of French and loosing :(
#5 PostAuthor: z1bman » Sun Feb 12, 2017 5:16 pm
they are different because one side has a bigger hole to take the nut
LeeJackson
#6 PostAuthor: LeeJackson » Sun Feb 12, 2017 5:36 pm
Yep confirmed on that, just wanted to check that they are both the same width or not? Zephyr ones are both different widths
pertonpc
#7 PostAuthor: pertonpc » Sun Feb 12, 2017 10:07 pm
I have my two adjusters out at the mo.
Will measure them for you tomorrow if I get a chance.
From Mark
LeeJackson
#8 PostAuthor: LeeJackson » Mon Feb 13, 2017 7:59 am
Perfect Mark ta
pertonpc
#9 PostAuthor: pertonpc » Mon Feb 13, 2017 8:36 am
Just checked my pair,
look pretty identical.
width = 395 mm
smooth diameter = 630mm
slotted edge outer diameter = 669 mm
taken from a 2001 1200R ZRX A1P model (they may differ ??)
LeeJackson
#10 PostAuthor: LeeJackson » Mon Feb 13, 2017 8:43 am
Spot on Mark, thanks for that!
Users browsing this forum: floydsz1 and 45 guests
