Chaps,
I was just removing my rear wheel to fine tune the chain alignment and the axle galled up in the chain adjuster I had fitted on the chain side. The adjuster I got with the swingarm were machined parts rather than genuine. Axle is jammed solid for now, but It was always a bit tight, so I decided to fit the zephyr ones I had instead.
When I matched them up side by side I noticed that the Zephyr ones are actually two different lengths, but the home made ZRX ones I had were not.. So I am wondering if the genuine ZRX ones are two different lengths? It will obviously affect the wheel alignment. Does anyone know what lengths the ZRX ones are supposed to be?
If they are different lengths, which side does each go on?
Lee
ZRX Chain Adjusters?
LeeJackson
LeeJackson
LeeJackson
LeeJackson
I have my two adjusters out at the mo.
Will measure them for you tomorrow if I get a chance.
From Mark
From Mark
LeeJackson
Just checked my pair,
look pretty identical.
width = 395 mm
smooth diameter = 630mm
slotted edge outer diameter = 669 mm
taken from a 2001 1200R ZRX A1P model (they may differ ??)
width = 395 mm
LeeJackson
Users browsing this forum: Google [Bot] and 75 guests
