engine oil grade .
ianali
engine oil grade .
#1 PostAuthor: ianali » Tue Feb 21, 2017 12:13 pm
What grade/makes of oil do people use these days please? Z1000 MK11 standard engine.
Ian.
wheelysteve
#2 PostAuthor: wheelysteve » Tue Feb 21, 2017 12:18 pm
I put this in all my bikes inc the Blackbird.
http://www.saisei-europe.com/Shop/Produ ... -1040-4lt1
Does the job and a good price from Dave at Saisei.
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
ianali
#3 PostAuthor: ianali » Tue Feb 21, 2017 12:26 pm
Thanks for reply. I have Some MorriS oils 10/40 semi synthetic that I put in my old car. Being a newly returned old bike owner I'm just finding out whats best to use! Not being cheapskate and happy to spend if the morris oil doesn't suit.
Cheers.
#4 PostAuthor: z1bman » Tue Feb 21, 2017 1:05 pm
morris's 10w40 will be perfectly ok
#5 PostAuthor: chrisu » Tue Feb 21, 2017 1:06 pm
need to use bike specific oil. other than that any semi synthetic 10/40 is absolutely fine.
#6 PostAuthor: Ultim8pc » Tue Feb 21, 2017 7:17 pm
I've used this before with no issues and it's cheap - Millers Oils ZSS 10w40:
http://www.emotorspares.co.uk/ecommerce/product/ECS157408.aspx
BigZCas
#7 PostAuthor: BigZCas » Tue Feb 21, 2017 8:25 pm
So are we saying that the Semi Synthetic 10w/40 oil "Ideal for petrol and diesel engines inc turbo etc etc" that i was recomended to use by a motor factors shop and tipped into my bike yesterday has to be drained and replaced with specific motorcyle oil ? :(
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
swampy
#8 PostAuthor: swampy » Tue Feb 21, 2017 8:33 pm
I only ever use bike specific oil in mine, there may be nothing wrong with other oils or there may very well be a reason. So that's why I use a bike oil as it gives me peace of mind.
#9 PostAuthor: z1bman » Tue Feb 21, 2017 8:42 pm
stevecastle wrote:So are we saying that the Semi Synthetic 10w/40 oil "Ideal for petrol and diesel engines inc turbo etc etc" that i was recomended to use by a motor factors shop and tipped into my bike yesterday has to be drained and replaced with specific motorcyle oil ? :(
it will be fine
#10 PostAuthor: zed1015 » Tue Feb 21, 2017 8:47 pm
Stick any 10/40 semi in and it will be just fine.
Even the cheapest supermarket own brand is as good or better than the top stuff from the 70's.
#11 PostAuthor: ZedHead » Tue Feb 21, 2017 9:27 pm
In simple terms yes. It has to be suitable for use with wet clutches to prevent slippage.
jphaynes669
#12 PostAuthor: jphaynes669 » Wed Feb 22, 2017 6:51 am
The majority of oil suppliers are doing bike speciric oils of various grades.
Ive always used putolene or similar without any issues, semi synthetics, but over the winter I have discovered that rockoil and belray are now doing a range of mineral oils of 10 w 40 and 20 w 50, (I have used 20 w50 in yamaha fours in hot weather ) grades.
The rock oil is named as Gamma, and the belray is called Exl mineral.
I will be trying the rock oil in my st 1000 this year, and I will post my opinions at some piont.
I, m sure we all maybe cocern ourselves touch much about these modern oils , and which is best, but most of them are more than suitable. I dont ride my old bikes hard at all , so if these oils can cope in these modern screaming four strokes, I think the internals in my old zeds will be just fine , I think in a lot of cases its just about preference on what oils we use. :up
Jeff.H
ianali
#13 PostAuthor: ianali » Wed Feb 22, 2017 7:50 am
Thanks for the replies. I think il use my morris oil then.
Ian.
BigZCas
#14 PostAuthor: BigZCas » Wed Feb 22, 2017 8:53 am
I guess in that case, If the clutch slips then I'll change the oil for specific motorcycle oil, if not I'll leave it.
Thanks all for advice.
Past 5 Years
1976 KZ1000a1, Red
#15 PostAuthor: zed1015 » Wed Feb 22, 2017 9:15 am
jphaynes669 wrote:Ive always used putolene or similar without any issues, semi synthetics, but over the winter I have discovered that rockoil and belray are now doing a range of mineral oils of 10 w 40 and 20 w 50, (I have used 20 w50 in yamaha fours in hot weather ) grades.
I will be trying the rock oil in my st 1000 this year, and I will post my opinions at some point.
The Rock oil TRM 20/60 works well .
Formulated for roller bearing cranks and contains long chain molecules.
Been using it in the fine weather only Zeds for a few years now.
Users browsing this forum: floydsz1 and 60 guests
