engine oil grade .
engine oil grade .
What grade/makes of oil do people use these days please? Z1000 MK11 standard engine.
Ian.
Ian.
- wheelysteve
I put this in all my bikes inc the Blackbird.
http://www.saisei-europe.com/Shop/Produ ... -1040-4lt1
Does the job and a good price from Dave at Saisei.
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
I've used this before with no issues and it's cheap - Millers Oils ZSS 10w40:
http://www.emotorspares.co.uk/ecommerce/product/ECS157408.aspx
So are we saying that the Semi Synthetic 10w/40 oil "Ideal for petrol and diesel engines inc turbo etc etc" that i was recomended to use by a motor factors shop and tipped into my bike yesterday has to be drained and replaced with specific motorcyle oil ?
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
1976 KZ1000a1, Red
stevecastle wrote:So are we saying that the Semi Synthetic 10w/40 oil "Ideal for petrol and diesel engines inc turbo etc etc" that i was recomended to use by a motor factors shop and tipped into my bike yesterday has to be drained and replaced with specific motorcyle oil ?
Stick any 10/40 semi in and it will be just fine.
Even the cheapest supermarket own brand is as good or better than the top stuff from the 70's.
In simple terms yes. It has to be suitable for use with wet clutches to prevent slippage.
- ZedHead
The majority of oil suppliers are doing bike speciric oils of various grades.
Ive always used putolene or similar without any issues, semi synthetics, but over the winter I have discovered that rockoil and belray are now doing a range of mineral oils of 10 w 40 and 20 w 50, (I have used 20 w50 in yamaha fours in hot weather ) grades.
The rock oil is named as Gamma, and the belray is called Exl mineral.
I will be trying the rock oil in my st 1000 this year, and I will post my opinions at some piont.
I, m sure we all maybe cocern ourselves touch much about these modern oils , and which is best, but most of them are more than suitable. I dont ride my old bikes hard at all , so if these oils can cope in these modern screaming four strokes, I think the internals in my old zeds will be just fine , I think in a lot of cases its just about preference on what oils we use.
Jeff.H
jphaynes669 wrote:Ive always used putolene or similar without any issues, semi synthetics, but over the winter I have discovered that rockoil and belray are now doing a range of mineral oils of 10 w 40 and 20 w 50, (I have used 20 w50 in yamaha fours in hot weather ) grades.
I will be trying the rock oil in my st 1000 this year, and I will post my opinions at some point.
The Rock oil TRM 20/60 works well .
Formulated for roller bearing cranks and contains long chain molecules.
Been using it in the fine weather only Zeds for a few years now.
