Z1000J Build
LeeJackson
#151 PostAuthor: LeeJackson » Tue Feb 14, 2017 9:10 pm
Correct Coose, as planned. So all good!
LeeJackson
Re: Z1000J Build
#152 PostAuthor: LeeJackson » Sat Mar 11, 2017 6:57 pm
Some goodies arrived today. Most important is the repairs head with all 8 studs now intact :)
I ended up sending it back to Debben's and Ray fixed it for free, got a cracking deal on the new gaskets etc and around 2 weeks from leaving France to being back in my garage. Can't ask for more than that..
Been cracking on refitting today and hopefully get fired up again tomorrow.
Re: Z1000J Build
#153 PostAuthor: Al » Sat Mar 11, 2017 10:45 pm
Thats a good result. I have this to come i suspect as i cant get my exhaust studs out and they are not that far from needing replacing!
Coose
Re: Z1000J Build
#154 PostAuthor: Coose » Sun Mar 12, 2017 8:39 am
Yep, that's good news! Are you leaving it (I assume) stock, or whilst it's off... :twisted:
LeeJackson
Re: Z1000J Build
#155 PostAuthor: LeeJackson » Sun Mar 12, 2017 9:56 am
Coose, it's not stock, already has big valves, brass guides, ported & flowed, web cams etc. hence why I was so upset when the stud broke :( anyway back on track now. Just triple checking my timing again today at some point.
Coose
Re: Z1000J Build
#156 PostAuthor: Coose » Sun Mar 12, 2017 10:19 pm
Nice! Definitely worth rescuing then rather than finding a replacement. :)
I'm watching as ever, and still hoping to get to Moto Coupés Légende...
LeeJackson
Re: Z1000J Build
#157 PostAuthor: LeeJackson » Sun Mar 12, 2017 10:37 pm
Oh the fun never stops.. Two stripped cam cap threads today.. Both been Helicoiled already and fortunately both helicoils have been recovered so will be attempting to refit some new ones as soon as the arrive.. Fortunately Al has been ever helpful and that's calmed me down a bit. Shame I didn't read any threads on using a jig to install the cams before I started and reducing the torque Vs the manual but hey ho such is life.. :smile we live and learn.
LeeJackson
Re: Z1000J Build
#158 PostAuthor: LeeJackson » Sat Apr 15, 2017 12:23 pm
Hoorah! So finally I have got back to where I was a couple of months ago... It's alive and Ticking!! The ticking noise was there last time I fired it up and I thought it was leaky header, but still there... Any ideas??
https://youtu.be/jPLCCsQRCR4
LeeJackson
Re: Z1000J Build
#159 PostAuthor: LeeJackson » Sat Apr 15, 2017 1:29 pm
Getting there.. Just completed second run in session as per Rays advice, still ticking loudly from the left side which needs further investigation!
Re: Z1000J Build
#160 PostAuthor: ZedHead » Sat Apr 15, 2017 3:27 pm
Rear shocks, front mudguard, fork brace, fork ears and other goodies with you next week Lee
LeeJackson
Re: Z1000J Build
#161 PostAuthor: LeeJackson » Sat Apr 15, 2017 3:36 pm
Spot on Dave.. Needing some more bits to fit now :)
Coose
Re: Z1000J Build
#162 PostAuthor: Coose » Fri Apr 21, 2017 6:42 am
That look grand Lee - is it staying red?
As well as the random cam knocking (new shells will be fitted at some point) mine has an intermittent tick too. I haven't yet pinned down from exactly where or what is causing it, but it only seems to happen when the motor is neither cold nor up to temp. Did you run yours until it was warm?
LeeJackson
Re: Z1000J Build
#163 PostAuthor: LeeJackson » Fri Apr 21, 2017 7:41 am
Hi Coose,
Yeah it was fully warmed up, I'm swaying towards it being electrical as Al had suspected but not had time to look at it this week as I've been on the road, next weekend will have time for a proper investigation.
On the Colours I have not finally decided. Originally I was going to go Lawson colours, but now the red is growing on me a lot and tempted to keep the standard colour scheme. I'm putting a bikini fairing on it but maybe that will look nice enough in original colours. Need to make my mind up soon as will have to get the bodywork dropped off for paint. Just waiting on fairing mountings and mudguard to arrive to test for everything first.
Re: Z1000J Build
#164 PostAuthor: Pigford » Fri Apr 21, 2017 1:35 pm
Ticking - has been known to be the TACHO take-off gear?
Kwackman
Re: Z1000J Build
#165 PostAuthor: Kwackman » Fri Apr 21, 2017 1:55 pm
LeeJackson wrote:On the Colours I have not finally decided.
I vote for the original red!
My old Z400J was that colour and my current project (another Z400J) will be, if I can get it working again.
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
