Won't engage 2nd gear
Fred the Zed
#1 PostAuthor: Fred the Zed » Thu Apr 06, 2017 7:33 pm
Hmm
Tracked down the Z1R's starting problem to a loose connection on the ignition circuit so it now fires up easily and runs well....
Booked it in for an MoT tomorrow so thought I'd just give it a (short) run down the drive to check it pulls away etc and although it engages 1st gear fine and pulls away fine it won't select 2nd. :down
I'm sure its down to the new clutch cable and PMC easy clutch kit I've installed since it last ran as it went through the gears fine before I laid it up a year or so ago but I just wanted to check there's nothing else it could be....? Any ideas?
Fred
Paid Up Member
Fred the Zed
Re: Won't engage 2nd gear
#2 PostAuthor: Fred the Zed » Thu Apr 06, 2017 8:31 pm
Tell me I haven't just discovered the positive neutral finder.... I've done some t'interweb research and it appears you can't select 2nd gear from a standstill on Kawasakis. I've had loads of Kawasakis before and never knew this!
I'm feeling a bit dim
Fred
Paid Up Member
trikerdrew
#3 PostAuthor: trikerdrew » Thu Apr 06, 2017 9:29 pm
On a brighter note
I often feel alot dim,LOL! :D
Fred the Zed
#4 PostAuthor: Fred the Zed » Thu Apr 06, 2017 9:57 pm
That's not helping... :lol:
I've just spent an hour trying to adjust the clutch cable only to find that where the Clymer manual says loosen the locknut and tighten the screw till it stops and then back it off half a turn it actually means loosen the screw. It might be an anomaly of having fitted a PMC easy clutch kit but man was I pissed off when I realised that I was adjusting the tension backwards. At least I kept the easy clutch instructions, all carefully filed away for future reference. It was only when I dug them out I remembered they were in Japanese, with some fairly unhelpful pictures.
I'm not tinkering again.... not for a while anyway.
Fred
Paid Up Member
Fred the Zed
#5 PostAuthor: Fred the Zed » Thu Apr 06, 2017 10:05 pm
and just to make me feel better about today's shenanigans, I go and find this:
'#5 PostAuthor: Pigford » Fri Nov 27, 2015 7:25 am
nicomkii wrote:
zed1015 wrote:
There's nothing wrong with it. It won't go into 2nd unless it's moving. It's called a positive neutral finder .
Shite, I better ask him about that. I just assumed he had been riding it in first trying to get into second......
The 1000's of people that must have been caught out by that over the years '
1001 now.
Fred
Paid Up Member
#6 PostAuthor: PAULJAC47 » Fri Apr 07, 2017 8:07 am
Put on the centre stand so back wheel turns,you can go through the box then without bike moving..
Julian_Boolean
#7 PostAuthor: Julian_Boolean » Fri Apr 07, 2017 9:19 am
Think youself lucky, I took the clutch cover off assuming there was something wrong with the gear change mechanism, and as I found out, on a Z it isn't behind the clutch.
Fred the Zed
#8 PostAuthor: Fred the Zed » Fri Apr 07, 2017 11:04 am
PAULJAC47 wrote:Put on the centre stand so back wheel turns,you can go through the box then without bike moving..
Ah... Cheers. I took the centre stand off so I could fit the PMC underslung caliper but I have a paddock stand....
Paid Up Member
Fred the Zed
#9 PostAuthor: Fred the Zed » Fri Apr 07, 2017 11:05 am
Julian_Boolean wrote:Think youself lucky, I took the clutch cover off assuming there was something wrong with the gear change mechanism, and as I found out, on a Z it isn't behind the clutch.
I feel better about it now! :D
Paid Up Member
Users browsing this forum: No registered users and 76 guests
