Front brake reservoir O ring
Is the O ring, that sits at the bottom of the front brake reservoir, available as a separate item?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
Re: Front brake reservoir O ring
not available as a separate part
I have them for the A1. Not sure if they are the same, perhaps give it a measure and let me know.
tlc wrote:I have them for the A1. Not sure if they are the same, perhaps give it a measure and let me know.
I thought the A1 had a round reservoir? If so then it probably won't fit but thanks for the reply.
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
and yet you are holding a round O ring.
Oh well.
Oh well.
Hey up
I will jump in on this thread cos I have the same situation and I bet the o ring is the same
What dot he o rings cost posted thanks
Reecy
Reecy
tlc wrote:and yet you are holding a round O ring.
Oh well.
It's not my hand - just a picture from an online site. The reservoir for the A1 is round while the A2 is more triangular so not sure if the O rings are different sizes?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
Mate.
It would make sense to me that the sealing of the reservoir is via a round portion and that the shape of the reservoir is immaterial.
Since that picture shows a round o ring, actually all o rings are round, all we need is the size and Bob's yer uncle.
I have shown the size of the rings so measure and ask and I will post FOC.
That's very decent of you so I'll take one if you don't mind. As you say, the inner size of the reservoir is probably identical. I'll pm my address.
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
Thanks 'Tic'... O-ring arrived today.
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
Lamentably, no. I need the smaller, Trapezoid, version. Redline, in the States (Ohio) do them...
http://redlinecycle.com/Brk%20-%20Fnt%2 ... Seals.html
I can return or forward the one you sent if you'd like?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
Shame but glad you found the one you need.
Just forward it on to anyone that needs it.
- ZedHead
It's just an O ring, they are sized by inside diameter, which you can measure from the groove and cross section which you can also measure from the groove. They come in various materials, look on E-bay and many sellers list them along with the material and what that material is good for and they are pence.
Mark.
Mark.
