a4 caliper shaft bolts
swampy
#1 PostAuthor: swampy » Sat Aug 05, 2017 8:17 pm
does anybody know if the a4 caliper shaft bolts are still available.
Mine are scruffy but could possibly be rechromed if new are not available.
Re: a4 caliper shaft bolts
#2 PostAuthor: z1bman » Sat Aug 05, 2017 8:32 pm
no longer available
swampy
#3 PostAuthor: swampy » Sat Aug 05, 2017 9:04 pm
bugger. does anyone produce re'manufactured ones then in stainless or chrome.
#4 PostAuthor: z1bman » Sat Aug 05, 2017 10:44 pm
found these but they are taking the piss if this is for one bolt
http://www.zed-parts.com/_p/prd1/426422 ... liper-bolt
swampy
#5 PostAuthor: swampy » Sun Aug 06, 2017 9:14 am
ffs they can shove that price where the sun dont shine £35 for one bolt.
#6 PostAuthor: Garry.L » Sun Aug 06, 2017 5:08 pm
Are you sure they weren't black originally?
My old Thou A1 (same caliper)...
#7 PostAuthor: PAULJAC47 » Sun Aug 06, 2017 5:15 pm
Agree with Gary, ones i have done have been black anodised type finish...
swampy
#8 PostAuthor: swampy » Sun Aug 06, 2017 7:14 pm
no I'm not sure, as they where/are badly painted black and have some surface rust.
CAT3
#9 PostAuthor: CAT3 » Sun Aug 06, 2017 7:58 pm
Don't know what the coating/plating was originally on these bolts, but it was a sort of drab/olive green finish.
The stainless steel ones in the link above look like they're machined to accept O-rings, which is a bit strange as the carriers have O-rings fitted.
£35 is very steep for one bolt though, I'm sure you should be able to have some made yourself for less than that !
#10 PostAuthor: Garry.L » Sun Aug 06, 2017 8:51 pm
swampy wrote:no I'm not sure, as they where/are badly painted black and have some surface rust.
The bolts on my old A4 were a bit shitty so when I rebuit the caliper I just polished the heads on the buffer which come up not far off chrome...
swampy
#11 PostAuthor: swampy » Sun Aug 06, 2017 9:36 pm
mine are deffo not stainless steel. hence the surface rust.
#12 PostAuthor: z1bman » Mon Aug 07, 2017 5:01 pm
the original bolts are black & not stainless steel
A1John
#13 PostAuthor: A1John » Mon Aug 07, 2017 5:23 pm
The caliper bolts are Olive Drab on both my z1000s.
swampy
#14 PostAuthor: swampy » Mon Aug 07, 2017 6:05 pm
ok. clean up and refinish it is then, thanks chaps.
DaveZ1
#15 PostAuthor: DaveZ1 » Tue Aug 08, 2017 9:52 pm
I have restored a few A4 calipers and the original finish on these bolts was olive drab ( same as the original finish on your carb clamps)
There are plating companies that will do this finish for you but I asked the platers I use for zinc plating all my nuts and bolts and they said they could achieve a black finish by zinc plating then black passivation. This produced a very durable black finish virtually indistinguishable from the original and cheap as chips!
Worth a try. :up
