Fork Springs Challenge
BigZCas
#1 PostAuthor: BigZCas » Wed Aug 30, 2017 6:01 pm
Really would like some help again :??
Attached photo's are the springs from my Z1a.
Manual says replace if under 496mm but does not say what they should actually be ?
Mine measure 523mm, this seems a bit excessive ?
Also I have caps in the ends but can find no reference to these for a Z1a.
If I load springs without caps they stick out of the tubes by 15mm, if I leave the caps on they stick out 25mm because the caps do not slide over the innards (maybe).
The opening at the other end of spring is larger so caps would not be gripped.
Any body out there come across this ?
Cas
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Re: Fork Springs Challenge
#2 PostAuthor: z1bman » Wed Aug 30, 2017 6:56 pm
standard length 495.5mm service limit 485mm
#3 PostAuthor: ADRIAN H » Wed Aug 30, 2017 6:59 pm
Standard spring length 495.5mm - Service limit 485mm.
BigZCas
#4 PostAuthor: BigZCas » Wed Aug 30, 2017 8:33 pm
That's strange, both Haynes and Clymer both agree for 73, Z1 but say service limit 496mm 74 / 75, Z1a & z1b ?
Have to know for sure and will cut down :??
Any idea on the caps ?
Past 5 Years
1976 KZ1000a1, Red
#5 PostAuthor: z1bman » Wed Aug 30, 2017 8:48 pm
taken from the genuine kawasaki manual . your fork springs are not the original they are after market heavy duty springs
BigZCas
#6 PostAuthor: BigZCas » Wed Aug 30, 2017 8:55 pm
Do you think it would be ok to cut down to 496 and leave the caps off the ends :?:
Past 5 Years
1976 KZ1000a1, Red
#7 PostAuthor: z1bman » Wed Aug 30, 2017 9:25 pm
if you are going to cut them you will have to use a slitting disc on a angle grinder then the end of the spring will need to be ground flat then you can still use the capped washers
Coose
#8 PostAuthor: Coose » Wed Aug 30, 2017 11:32 pm
Before you chop them I would fit them and measure the sag as it's not a black art and will potentially save you a lot of work. Anywhere between 35 and 45mm of laden sag would be fine.
garyd
#9 PostAuthor: garyd » Thu Aug 31, 2017 7:24 am
I've got a pair of springs if you want them.
I'll measure them later today.
#10 PostAuthor: zed1015 » Thu Aug 31, 2017 8:32 am
They are HD springs and I would leave them in.
The stock suspension is soft as shit and these springs help the handling.
If you really want stock springs then buy some or trade with another member.
Cutting these springs won't soften them up but just reduce the preload and increase the static sag.
The spring rate will remain the same.
BigZCas
#11 PostAuthor: BigZCas » Thu Aug 31, 2017 9:49 am
One of my concerns was that they protrude 25mm out of the fork stanchion and will prove difficult to get the fork tops started ?
Although someone must have got them in before :lol:
Past 5 Years
1976 KZ1000a1, Red
#12 PostAuthor: zed1015 » Thu Aug 31, 2017 11:00 am
All fork springs need compressing to some degree by the cap before starting the thread.
Done plenty and it isn't difficult, just make sure the fork slider is hanging free so it is fully extended (wheel off the floor if doing it with the forks in the bike).
Use a T bar and socket to help push the cap down squarely whilst turning.
To prevent any marking of the hex head by the socket use a bit of plastic bag between it and the socket.
#13 PostAuthor: ZedHead » Thu Aug 31, 2017 8:18 pm
It is good to see that good advise is still forthcoming from experienced people on this forum.
I agree about the HD springs. Zeds were always on the soft side.
BigZCas
#14 PostAuthor: BigZCas » Thu Aug 31, 2017 9:22 pm
Thank you everyone for your help and advice :)
After considering all, I have decided to use the same spings as removed and see how it goes on assembly.
Cas
Past 5 Years
1976 KZ1000a1, Red
garyd
#15 PostAuthor: garyd » Fri Sep 01, 2017 6:01 am
Hewre's something for the experts. I have two pairs of spring which I beleive came out of Z1000A1 forks.
They measure 465mm.
Did the internals change that much from the Z1?
Users browsing this forum: Andy M, Google [Bot], r3sc and 39 guests
