What engine case sealant?
Blackseven
#1 PostAuthor: Blackseven » Fri Dec 22, 2017 10:25 am
I'm going to reassemble my engine soon following having the cases vapour blasted and was wondering what sealant is recommended for the top to bottom case joint?
I have some ThreeBond TB1215 grey silicone sealant but am not sure if this is the best thing to use. I've also heard of ThreeBond 1105B a.k.a. Kawabond and also MIchel semi-drying gasket cement.
Any recommendations from people who have been there and done this?
Thanks in advance, Rob
GPZ592
Re: What engine case sealant?
#3 PostAuthor: GPZ592 » Fri Dec 22, 2017 11:21 am
I've used the Michel gasket cement on my GPz crankcase joints with no problems.
#4 PostAuthor: chrisu » Fri Dec 22, 2017 1:25 pm
always used kawabond or yamabond or the maker equivalent. never had a problem.
Wrigers
#5 PostAuthor: Wrigers » Fri Dec 22, 2017 3:06 pm
Had some Three Bond left after the Kettle rebuild and that worked a treat, so i used it again in my A4 re build,
shouldn't be a problem, more or less doing the same job.
Robw
#6 PostAuthor: Robw » Fri Dec 22, 2017 4:13 pm
Black Loctite sealant from Halfords
#7 PostAuthor: ADRIAN H » Fri Dec 22, 2017 7:11 pm
Blackseven
#8 PostAuthor: Blackseven » Fri Dec 22, 2017 9:18 pm
Thanks for the replies.
I was wondering if I should use a silicone type that cures (like V-Tech or Threebond 1200 type) or a semi-drying type (like Threebond 1100 or Michel).
It seems that people have used both types successfully on cases so I'm probably over thinking it and will just use the Threebond 1215 silver sealant that I already have.
Rob
Andy M
#9 PostAuthor: Andy M » Fri Dec 22, 2017 9:26 pm
Mr Bump
#10 PostAuthor: Mr Bump » Fri Dec 22, 2017 9:55 pm
Robw wrote:Black Loctite sealant from Halfords
Yep.
Lemmy
FOZ1A
#11 PostAuthor: FOZ1A » Sat Dec 23, 2017 9:35 am
I thought this was the best stuff to use :
https://www.ebay.co.uk/itm/STAG-WELLSEA ... SwNf1ZtiT8
foz
Kwackman
#12 PostAuthor: Kwackman » Sat Dec 23, 2017 10:34 am
FOZ1A wrote:I thought this was the best stuff to use :
foz
Yeah, that was recommended to me too by a mate who rebuilds his (car) racing engine regularly.
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
DogsbolloxofZ1B
#13 PostAuthor: DogsbolloxofZ1B » Sat Dec 23, 2017 9:55 pm
Kawabond every time. Make sure mating faces are fully
degreased with something like brake/clutch cleaner.
