Where does this go?
relisysxx
Where does this go?
#1 PostAuthor: relisysxx » Sat Dec 30, 2017 7:49 pm
Just about to start building my z900 motor and I can't for the life of me remember where this Goes, any idea's?
Re: Where does this go?
#2 PostAuthor: z1bman » Sat Dec 30, 2017 8:13 pm
it should also have a spring & a plunger & it screws into the crank case above the shift drum
relisysxx
#3 PostAuthor: relisysxx » Sat Dec 30, 2017 9:55 pm
No I've got that one and the one that screws into the selector, drawn a blank on this though.
Wouldn't be as bad if I bought the motor as a box of bits but I took it apart!!
#4 PostAuthor: zed1015 » Sat Dec 30, 2017 10:17 pm
It's the Oil pressure bypass valve ( Not neutral detent plunger).
It's missing a spring and ball bearing.
It screws in the top of the oil filter chamber from above in the lower case half before the crankcases are assembled.
When installed you can see the tip on the ball bearing through a small hole in the roof of the filter chamber .
relisysxx
#5 PostAuthor: relisysxx » Sat Dec 30, 2017 10:26 pm
That's it! I knew it had to go somewhere.
Thanks guys
