Swinging arm spacer
Re: Swinging arm spacer
#16 PostAuthor: ZedHead » Fri Feb 09, 2018 8:51 am
8 Valve Mark wrote:I've got about 40 metres of 22mm o/d x 2mm gauge stainless tube from a microlight project.im sure i could cut,pack and post to members for £15-£20 ish.depending on whether there is much demand..any enquiries welcome. cheers mark
Presumably, the extra 1mm i/d clearance this would give is not as critical as the length needed to distance the sleeves?
#17 PostAuthor: zed1015 » Fri Feb 09, 2018 10:58 am
Inside diameter isn't as critical as the length as long as the wall thickness isn't so thin as to risk crush distortion when tightened.
2mm wall will be ok.
chrisw1
#18 PostAuthor: chrisw1 » Fri Feb 09, 2018 7:24 pm
The length is 141.5mm if it helps
8 Valve Mark
#19 PostAuthor: 8 Valve Mark » Fri Mar 16, 2018 10:47 pm
the inner diameter clearance is just 'grease room'..
#20 PostAuthor: ZedHead » Mon Mar 19, 2018 7:37 am
8 Valve Mark wrote:the inner diameter clearance is just 'grease room'..
Are you going to make some?
8 Valve Mark
#21 PostAuthor: 8 Valve Mark » Sat Mar 24, 2018 9:18 pm
I'll make a few n see how the interest goes.why not? a sleeve/2 bearing kit might also make sense, ill see my bearing guy next week to explore the best prices available. ps sorry about the delay getting back just had life getting in the way of real stuff. ride safe, mark
Ratty
#22 PostAuthor: Ratty » Sat Mar 24, 2018 10:35 pm
Hi Mark,
Put me down for a set, with bearings.
Thanks,
Ratty
8 Valve Mark
#23 PostAuthor: 8 Valve Mark » Sun Mar 25, 2018 10:34 pm
cheers ratty, no problem mate . it'll probably be easter weekend before i can get some bench time, but I'll keep you posted regarding price inc postage etc. good luck with the new project btw :smile cheers mark
Ratty
#24 PostAuthor: Ratty » Mon Mar 26, 2018 9:52 pm
Thanks Mark, no hurry as these are for the latest acquisition and that is currently 4th in the queue for attention :lol:
#25 PostAuthor: ZedHead » Tue Mar 27, 2018 7:54 am
Will you need to use Top Hat caps on the outside if replacing the bushes with bearings?
8 Valve Mark
#26 PostAuthor: 8 Valve Mark » Sat Mar 31, 2018 9:10 pm
hi zedhead, apologies about the delayed reply :having looked into it, it's not really worth it for me to supply bearings/bushes as I'm sure you know, they're readily available at affordable prices already. I'll instead concentrate on supplying my stock of 22mm tube to members covering most z models from z1-z11. mark
#27 PostAuthor: ZedHead » Sun Apr 01, 2018 10:54 am
8 Valve Mark wrote:hi zedhead, apologies about the delayed reply :having looked into it, it's not really worth it for me to supply bearings/bushes as I'm sure you know, they're readily available at affordable prices already. I'll instead concentrate on supplying my stock of 22mm tube to members covering most z models from z1-z11. mark
Thanks Mark, I would be interested to know if anyone has successfully made a needle roller conversion and what they used?
Good luck with the spacers, birth of another cottage enterprise.
Users browsing this forum: Google [Bot] and 100 guests
