smoking exhaust
johnA
smoking exhaust
#1 PostAuthor: johnA » Fri Jun 22, 2018 9:15 pm
hello gents i finally got round to starting my gpz1100 after the winter lay up today and the left hand side exhaust is smoking quite a bit and it didn't before the lay up. any ideas what could be causing it the bike was on its centre stand all winter. i didn't bother taking it for a run as the battery decided to die as well.
many thanks in advance john
Re: smoking exhaust
#2 PostAuthor: z1bman » Fri Jun 22, 2018 10:29 pm
possibly valve seals but i would ride it for a couple of hundred miles before you start to worry if it still has its fuel injection still fitted ? if it has been converted to carbs they would be the first port of call
Re: smoking exhaust
#3 PostAuthor: kev edwards » Sat Jun 23, 2018 8:18 am
Black,blue or white smoke?
markgb
Re: smoking exhaust
#4 PostAuthor: markgb » Sat Jun 23, 2018 11:08 am
Hi I have the same problem with my Z1B Been off the road for winter had carbs cleaned but I have Blue / White smoke from mine done about 150 miles on it but still smoking ??????
Z1B Happy Days Get the Z out and go for a Blast
Re: smoking exhaust
#5 PostAuthor: zed1015 » Sat Jun 23, 2018 11:26 am
White/blue smoke = oil burning.
It's common when the bike has been stood for a while and it should clear up after a few miles.
If not it's most likely the stem seals on their way out.
Not a big problem until you start using more oil than petrol and you resemble one of the red arrows tearing down the high street.
johnA
Re: smoking exhaust
#6 PostAuthor: johnA » Sat Jun 23, 2018 9:38 pm
ha ha not that bad yet thanks very much for your replies.
Users browsing this forum: Bing [Bot] and 45 guests
