A few bits'N'peices.
Z1000 caliper and arm £10
Z1000 centre stand £35 has some wear marks but has been coated recently
New PMC gearbox/output shaft bearings. £75 ( These are £155 from ZPower)
Z1000 rear brake levers £7 each
Rear wheel adjusters with Stainless bolts £10
Kiststart £25
GPZ/J type Brake levers FREE...who wants them!
Brake calipers two different types £10 each.
APE set of 7 valve guides ( Handy if you don't need to do them all!) £40
Kiststart £25
Re: A few bits'N'peices.
Can I have the centre stand if still available please Gary
Cheers Ian
Cheers Ian
PUM 13
Centre stand Sold
Hi Gary can I have the two front calipers please. Sean.
I'll take thd bearings. PM sent
I'll take the guides.
Pm Sent.
Pm Sent.
Bearing, guides and calipers sold.
Gary, I will take rear Cali per and arm, z1000 rear brake pedal and kickstart.
Foz
Foz
Pm your addy Foz and i'll get them in the post
Yup. still there
Most of the time...half term hols
Just out on accasions but should be able to open up Cafe du Gary when needed.
can I take the rear wheel adjusters please if still available. cheers
bunnysZ wrote:can I take the rear wheel adjusters please if still available. cheers
Yours...PMed you back
Users browsing this forum: SuffolkZ1r and 32 guests
