GPZ1100 Cylinder head blank off plates
Gus
#1 PostAuthor: Gus » Wed Oct 24, 2018 5:06 pm
Evening Gents
Before I go all Blue Peter does anybody have a quick solution to blocking of the injector ports in the cylinder head or a template / method I could use?
Cheers Amigos
Gus
"Set the GRINDER on it"
Re: GPZ1100 Cylinder head blank off plates
#2 PostAuthor: ADRIAN H » Wed Oct 24, 2018 6:41 pm
APE make these. - http://kzzone.com/billet.html
Debben performance or Grumpy1260 should be able to get you some.
Gus
#3 PostAuthor: Gus » Wed Oct 24, 2018 6:44 pm
Hi Adrian
Thanks for the reply.
They're the ones for the emmission caps on the cam covers.
I need something for where the injectors bolt into the inlet tract on the cyl. head.
Gus
Gus
#4 PostAuthor: Gus » Wed Oct 24, 2018 6:51 pm
#5 PostAuthor: Al » Wed Oct 24, 2018 7:10 pm
Gus
#6 PostAuthor: Gus » Wed Oct 24, 2018 7:17 pm
Thanks Al.
Gotta be worth asking them some questions.
Gus
rpeters
Bristol's "H" Hoarder
#7 PostAuthor: rpeters » Thu Oct 25, 2018 6:25 am
Hi Gus,
I think I have some that i have removed from H heads recently (unless I binned them!), I will take a look.
Do you have the rubber seals from the bores?
Rob
paid up member
Gus
#8 PostAuthor: Gus » Thu Oct 25, 2018 8:10 am
Hi Rob
No I don't have rubbers either, I was looking if I could use "O" rings but the recess is too deep.
Gus
rpeters
#9 PostAuthor: rpeters » Sat Oct 27, 2018 3:29 pm
What’s your mobile gus?..
Or call me on 07920 422205.
I have the plugs
paid up member
Users browsing this forum: No registered users and 84 guests
