Evening Gents
Before I go all Blue Peter does anybody have a quick solution to blocking of the injector ports in the cylinder head or a template / method I could use?
Cheers Amigos
Gus
GPZ1100 Cylinder head blank off plates
"Set the GRINDER on it"
Re: GPZ1100 Cylinder head blank off plates
APE make these. - http://kzzone.com/billet.html
Debben performance or Grumpy1260 should be able to get you some.
Hi Adrian
Thanks for the reply.
They're the ones for the emmission caps on the cam covers.
I need something for where the injectors bolt into the inlet tract on the cyl. head.
Gus
Gus
Unlikely they will be the correct hole centres but a bit of fettling might get it.
https://www.ebay.co.uk/itm/Classic-Mini ... rk:13:pf:0
Same seller
https://www.ebay.co.uk/itm/CLASSIC-MINI ... SwDYxbuL-j
And again
https://www.ebay.co.uk/itm/Classic-Aust ... Sw0RlbuL59
Same seller
And again
Thanks Al.
Gotta be worth asking them some questions.
Gus
Gus
Hi Gus,
I think I have some that i have removed from H heads recently (unless I binned them!), I will take a look.
Do you have the rubber seals from the bores?
Rob
Rob
paid up member
Hi Rob
No I don't have rubbers either, I was looking if I could use "O" rings but the recess is too deep.
Gus
Gus
What’s your mobile gus?..
Or call me on 07920 422205.
I have the plugs
I have the plugs
paid up member
Users browsing this forum: celger7 and 18 guests
