Gpz1100b1 rear sets
scott
Junior Section leader
Gpz1100b1 rear sets
#1 PostAuthor: scott » Thu Jan 03, 2019 3:51 pm
Guys, what different types of aftermarket rear sets are out there for Gpz1100b1. I would like some sort of ability to take a passenger if possible.
Gus
Re: Gpz1100b1 rear sets
#2 PostAuthor: Gus » Thu Jan 03, 2019 4:31 pm
"Set the GRINDER on it"
#3 PostAuthor: chrisNI » Thu Jan 03, 2019 4:58 pm
I flogged a set of Tarozzis a couple of weeks ago with rear pegs to go with them. Not much help to you but if you look for the For Sale post you’ll see the setup. On a 1000R but would be the same.
Gus
#4 PostAuthor: Gus » Thu Jan 03, 2019 5:06 pm
chrisNI wrote:I flogged a set of Tarozzis a couple of weeks ago with rear pegs to go with them. Not much help to you but if you look for the For Sale post you’ll see the setup. On a 1000R but would be the same.
Chris.
Do you think it is possible to mount the rear sets through the original hanger mounting holes and therefore be able to fit a set of single tarozzi rear pegs or keep the original pegs in the original hangers?
Gus
#5 PostAuthor: Al » Thu Jan 03, 2019 5:14 pm
Tomforde in Germany again, does some very nice ones but a little pricey.
https://www.ebay.co.uk/itm/Aluminium-Ma ... :rk:3:pf:0
#6 PostAuthor: Al » Thu Jan 03, 2019 5:17 pm
#7 PostAuthor: Al » Thu Jan 03, 2019 5:24 pm
Showing one left in stock at Disc V.
Need to specify folding or non folding footrests!!
https://www.discovolantemoto.co.uk/kawa ... 1141-p.asp
#8 PostAuthor: chrisNI » Thu Jan 03, 2019 9:22 pm
Gus
The Tarozzi rearsets I had used the hanger holes so I don’t think you can use both with that type. The ones in Al’s link are different and seem to use the hangers. The best bet with the non hanger type is a set of clamp on rear pegs like the ones I sold too, unfortunately I don’t know what they came off originally.
scott
#9 PostAuthor: scott » Thu Jan 03, 2019 10:55 pm
I like the Tomforde ones. That covers the riders pegs, what could I do for the rear pegs?
Gus
#10 PostAuthor: Gus » Fri Jan 04, 2019 10:47 am
These are the rear pegs Chris had.
They could be an option if we knew what they were off.
If anybody recognises them that would be a great help as I could do with some also.
I'm a tight git and would prefer the buy this type off ebay option :lol:
Gus
Julian_Boolean
#11 PostAuthor: Julian_Boolean » Fri Jan 04, 2019 1:10 pm
Raask rearsets have pillion peg mounts, try M and P for them.
Gus
#12 PostAuthor: Gus » Fri Jan 04, 2019 1:16 pm
scott
#13 PostAuthor: scott » Fri Jan 04, 2019 1:44 pm
The Raask ones seem ok but can’t see where the pillion pegs would be.
Julian_Boolean
#14 PostAuthor: Julian_Boolean » Fri Jan 04, 2019 4:25 pm
scott wrote:The Raask ones seem ok but can’t see where the pillion pegs would be.
The holes right at the back are for pillion pegs, the big holes are for the exhaust mounts.
The riders footpegs are quite a long way back.
#15 PostAuthor: Ginger Bear » Fri Jan 04, 2019 5:57 pm
Gus
A lot of sportbike pegs can be easily adapted, either by welding a tab under the downtube or drilling and welding in a sleeve. Pictured are early R1 pegs.
R1 pegs.jpg (5.97 KiB) Viewed 5933 times
# 104
