Guys
anyone ever changed the seals head on ? I am talking about as in car engines etc with a length of rope in the bore ?
is it possible on a Z ?
Z1000 a1 Valve stem seals head on
Re: Z1000 a1 Valve stem seals head on
Can be done as you say - but fiddly, so probably better to bite the bullet & give her a good decoke & check whilst you're at it.
- warren3200gt
How would you compess the valve spring to release the colletts?
warren3200gt wrote:How would you compess the valve spring to release the colletts?
You use a compressor that bolts to the top of the head.
Valve can also be kept from dropping by using compressed air instead of rope.
- warren3200gt
zed1015 wrote:warren3200gt wrote:How would you compess the valve spring to release the colletts?
Hmm, not seen one of those, always used the G clampy shaped ones. So head off.
- warren3200gt
So your supposed to bolt it to the cam caps or the cam cover ?
