zed1015 wrote:Gus wrote:Crikey![]()
What if I want to use the standard top mounts?
Gus
If the S/A shock mounts are wider than mounts on the frame you can buy or get made some screw on extensions for the original top shock mounts.
Yes I got some shock mount extensions off here. I was wondering about the shock angle to the swing arm is it just a case of matching the original or maybe going slightly steeper to allow for the smaller wheel?
Gus
