Cam chain assy needed
GreenMamba
#1 PostAuthor: GreenMamba » Thu Jul 04, 2019 8:11 pm
As the title reads I need the whole Shabang but Z Power wants 720 for it and I’m broke as it is any help or recommendations
Re: Cam chain assy needed
#2 PostAuthor: zed1015 » Thu Jul 04, 2019 10:23 pm
You will need to buy new as any used stuff will most likely be on it's last legs.
Go for PMC or Liska stuff on the idler sprockets and mounts as it's cheaper then OEM and eliminates the rubber which degrades on the stock idler sprockets so will last virtually forever.
The lower rubber wheel and front guide are also available from good aftermarket suppliers.
flateddie
#3 PostAuthor: flateddie » Fri Jul 05, 2019 7:38 pm
I am sure Dave at Cybike was closer to 350 ish
GreenMamba
#4 PostAuthor: GreenMamba » Fri Jul 05, 2019 8:41 pm
Yes I have made up a list at cybike now just got to get all the cas today it’s not going to be a cheap rebuild maybe I’ll beg for a discount :blush
#5 PostAuthor: zed1015 » Fri Jul 05, 2019 10:25 pm
Done right the motor will last for years and the initial expense will more than pay for itself.
I'm 20 years in on my Z1R since the last proper rebuild and it's still a strong motor.
This is my true everyday ride that's done a couple of hundred thousand miles not a show pony.
GreenMamba
#6 PostAuthor: GreenMamba » Sat Jul 06, 2019 6:55 am
Agreed zed these motors are bulletproof it’s just a lot of overtime :wink:
Users browsing this forum: LeeJackson and 35 guests
